Author Topic: micro SS power amps  (Read 2515 times)
dheim
  • DON'TPANIC!
micro SS power amps
« on: January 31, 2010, 02:54:43 PM »
do you know of any micro power amp that's more powerful than the EHX 22 caliber for emergency use in live situations? i'd say 50 W...
too many? ;)
jibidy
Re: micro SS power amps
« Reply #1 on: January 31, 2010, 03:00:45 PM »
Crate powerblock might be a good one.
Other than that im not sure unless you ant another head altogether.
psy
    • Me singing & guitaring
« Reply #3 on: January 31, 2010, 04:25:04 PM »
If you can find one I'd second the Crate Powerblock.  That's what I use as back up.  Small enough & light enough to fit in my bag with my effects & leads.  Even use it for band practise sometimes when I don't fancy taking my rack.
Mine has gone silent after 4 years of pretty heavy use though, so it's with HTH at the moment to see if it can be fixed.
Oli
« Reply #4 on: January 31, 2010, 06:31:10 PM »
If you do happen to like the look of the powerblock, i've got one that I keep meaning to put on eBay, so give me a shout :)
dheim
  • DON'TPANIC!
« Reply #5 on: February 01, 2010, 01:42:08 AM »
i definitely like its look!
i was looking for something different (a simple final stage to use with a POD or similar as a pre), but if i'll manage to find some sample (and i like them, of course) i'll let you know very soon!
too many? ;)
psy
« Reply #6 on: February 01, 2010, 10:42:25 AM »
If you're using a modelling pedal with the Powerblock you can plug it in to the Line-In on the back & that bypasses the Preamp/EQ section & goes straight to the poweramp (you have to control your volume from the pedal though & not the amp if you do that).
  • Truly bad since 1972
« Reply #7 on: February 01, 2010, 02:26:50 PM »
great little amps...for what they do
