November 20, 2026, 02:34:36 PM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Guitars, Amps and Effects
Pedal advice GNR
Pedal advice GNR
Started by sgmypod, February 01, 2010, 04:53:51 PM
Previous topic
Next topic
Print
Go Down
Pages
1
2
3
User actions
Welterweight
Truly bad since 1972
Logged
Pedal advice GNR
Last Edit
: February 01, 2010, 04:55:32 PM by sgmypod
Have a 50w valve amp el34 based will do crunch...but not much higher gain, for stuff like you could be mine what pedal would people recommend.
Light Heavyweight
Logged
Re: Pedal advice GNR
#1
February 01, 2010, 04:58:27 PM
Marshall Guv'nor or Tonerider British Distortion or MI Audio Crunch Box...
Welterweight
Logged
#2
February 01, 2010, 05:01:27 PM
you got all of the above
Light Heavyweight
Logged
#3
February 01, 2010, 05:08:31 PM
No longer got the Crunch Box, still got the other two. Guv'nor is more gritty, Tonerider is very similar to the Crunch Box, if not identical. A bit smoother.
Welterweight
Logged
#4
February 01, 2010, 05:09:20 PM
which has best bass end
Light Heavyweight
Logged
#5
February 01, 2010, 05:10:52 PM
Neither - lots of gain and lots of bass = super flabbiness.
Welterweight
Logged
#6
February 01, 2010, 05:12:26 PM
reword this...don't like over thin, over top treble sounding pedals...
Light Heavyweight
Logged
#7
February 01, 2010, 05:19:34 PM
Crunch Box or British Distortion would probably suit you better then!
Welterweight
Logged
#8
February 01, 2010, 05:33:02 PM
cool will have a look out for both..see if can get one at a good price
Middleweight
Logged
#9
February 01, 2010, 06:00:45 PM
Going for GnR you will have to do without a lot of bottom end/lower mids. That tone is all about upper mid crunch.
OCD would be great into a dirty amp, but it's not that cheap.
Matt77
Guest
Logged
#10
February 01, 2010, 06:02:20 PM
MXR - 10 band EQ put in the loop?
Think that may have been used on a lot of the use your illusion stuff
Welterweight
Logged
#11
February 01, 2010, 06:09:22 PM
already a have a ocd..is not quite there for me
Plexi Ken
Lightweight
Logged
#12
February 01, 2010, 06:22:54 PM
Not used one but how about Rothwell Hellbender?
http://www.youtube.com/watch?v=Is4sFNZeuwQ
Middleweight
Logged
#13
February 01, 2010, 06:25:49 PM
MI Audio Crunchbox for sure - owned one and it did that kind of thing great.
Or, you could simply use a SD-1 into your Laney GH50L - that should get you there. An MXR 6-band EQ would be a cool way to get that tone too.
shobet
Welterweight
Look into my eye...
Logged
#14
February 01, 2010, 06:28:53 PM
I could swear I remember him going on about MXR Distortion+ in an interview I read somewhere. Also try an older RAT pedal.
I'd avoid anything Tube Screamer derived as I don't think that will give you the sound.
I think you'll generally struggle unless you've got a big Marshall running at a very loud volume.
Print
Go Up
Pages
1
2
3
User actions
Forum Ringside
Pedal advice GNR
User actions
Print
