Author Topic: Advice on removing pickup covers  (Read 4727 times)
Mr_Ibanez
    • My Band
« on: February 11, 2010, 03:44:30 PM »
Hey there!
I need your advice on removing pickup covers.
The thing is: I've got a painkiller in a 7-string RG (basswood body) without covers and a painkiller with covers in a 6-string RG (mahagony). Both guitars are tuned to B and got the same string gauge, but sound very differently.
Ok, I know, wood and mass contribute to the sound, still the mahagony guitar is way darker in sound than the basswood. Additionally the 7-string seems to have more attack although pickup height is aprox. the same. I've never experienced such huge difference in that matter.
Now: would removing the cover the 6-string pickup lead to a brighter and maybe even attackier sound?
Has anyone ever had a problem like that?
Greetings,
Alex
« Last Edit: February 11, 2010, 03:46:46 PM by Mr_Ibanez »
BigK
Re: Advice on removing pickup covers
« Reply #1 on: February 12, 2010, 05:46:21 PM »
Covers can roll off the high treble slightly but its not alot of difference. However Tim compensates for this in the wind.
I would have a look at changing the pots for some high quality 500k ones or even 1meg pots if you want to brighten up your tone a little.
How do the guitars sound acoustically compared to each other?
also the bridge's on each guitar play a part too.
« Reply #2 on: February 12, 2010, 06:05:20 PM »
not entirely an unexpected result.
BKPs do highlight differences in guitars alot more than typical commercial brands
mahogany can be very dark
Mr_Ibanez
    • My Band
« Reply #3 on: February 12, 2010, 06:20:36 PM »
That's what I thought, too. Then again: attack. It just seems like the basswood guitar has more gain to it apart from clarity and brightness.
Acoustically the basswood 7-string sounds naturally brighter. Both bridges are Ibanez Floyds: the mahagony's got a double edge, the basswood's got a edge pro.
« Reply #4 on: February 15, 2010, 11:32:19 AM »
basswood has a reputation for more compression/gainier tone. i'm not generally a basswood fan, so have no basswood guitars to comment more here.
« Reply #5 on: February 15, 2010, 12:28:56 PM »
Actually removing covers can sometimes be tricky -
You need to get the pickup hot to stop the wax in it holding onto the cover and also desolder the base from the cover too.
I will often use a soldering iron and solder wick to get the solder join off the baseplate , and then pop the pickup in my wax bath for half an hour to melt the wax
Sometimes you can just apply a little heat to the cover with a lighter enough to loosen the wax's grip and gently wiggle the cover off.
Mr_Ibanez
    • My Band
« Reply #6 on: February 15, 2010, 01:49:39 PM »
I'm sorry, I just realised that the subject might be a little misleading.
Actually I wouldn't remove the covers myself, that would be Tim's job ;) Only in case I decide to go that step...
