Author Topic: What pickups are you using in basswood?  (Read 4046 times)
Js90lx
« on: February 11, 2010, 04:46:12 PM »
Just wondering? I have a C-pig in the bridge of my RG550 not sure I'm getting along with it. I LOVE my Miracle Man set in my Les Paul.
Les Paul Classic/Miracle Man set
Ibanez RG550XX C-Pig and MQ
Jackson SL2H ????
sjwebb90
Re: What pickups are you using in basswood?
« Reply #1 on: February 11, 2010, 06:57:08 PM »
I have a Nailbomb in the bridge and two Irish tours in my Charvel 475.
Cheers
Simon
DimeZakk
« Reply #2 on: February 11, 2010, 07:31:33 PM »
An Alnico Warpig would have been the wiser choice in basswood I think...
Nailbombs work really well in basswood and so do normal Warpigs - You might wanna get the magnets changed if you like where the C-Pig is going...
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
« Reply #3 on: February 12, 2010, 02:01:21 AM »
I've got a Nailbomb, Miracle Man, VHII and Painkiller all in basswood. All sound different but all good.
I see a rainbow rising
Look there on the horizon
And I'm coming home
« Reply #4 on: February 12, 2010, 11:41:10 AM »
I have a miracle man in a basswood ibanez RG430F/TBL. It's great! Not a patch on the black dog in that WezV vociferator you see in my avatar, though ;)
MM in basswood for me handles the low end well, with screaming pinch harmonics unfeasibly easy, but has a great tightness to the tone, along with real aggression. That's on downtuned stuff, mind.
Hope this helps,
Roo
JamesHealey
« Reply #5 on: February 12, 2010, 12:28:14 PM »
Nailbomb works well in basswood..
« Reply #6 on: February 12, 2010, 02:31:35 PM »
I have a Nailbomb set with Irish Tour middle pickup and also a Stormy Monday with 2 Sultans in a strat.  Both sound good, but the SM/Sultans get some great classic rock and heavy tones that you wouldn't expect (especially through a JTM45).
Davey
« Reply #7 on: February 12, 2010, 03:35:17 PM »
i got a warpig in my charvel fusion
Js90lx
« Reply #8 on: February 15, 2010, 01:35:55 AM »
The guitar is tuned down a whole step. I use this guitar for children of bodom, death, and firewind mostly. I was pondering a c-bomb but I wonder if I should try a pickup with an alnico magnet? I have always used a ceramic pickup though.
Jackson SL2H ????
« Reply #9 on: February 15, 2010, 12:48:24 PM »
if it's only a tone down, I'd stick with ceramic. You're presumably not using a long scale length and fat strings on there. Course, it depends on your amp to a certain degree, too, and your style of playing. I use huge strings on a baritone tuned down to A-E-A-D-F#-B, and I hit them very hard, so a black dog gives just the right amount of push into a boosted 5150 to get utterly filthy. I never had a problem with a miracle man in a basswood ibanez (25.5" scale) in the same tuning with a set of 13s, although that was unboosted into the same amp.
Upshot: Unless you slam the front end of your amp particularly hard, I think you're better off with ceramic pickups.
Roo
Madsakre
« Reply #10 on: February 26, 2010, 06:33:42 PM »
I've got a Alnico V warpig in my RG7321
Cattlepress
Js90lx
« Reply #11 on: March 13, 2010, 03:01:28 AM »
So I had tried adjusting the pickup height before and could not get it to work out. Today I tried again and went pretty low with it. I finally found the sweet spot for this pickup. It kicks so much tail now. I love the grind!
Jackson SL2H ????
