Author Topic: the C-pig in basswood dont comes out....  (Read 2673 times)
mesallover
« on: February 15, 2010, 11:24:16 PM »
i have a C-pig in a ibanez RG2570
[ BASSWOOD body , maple neck ] TUNING : C#
but... the suond dont comes out from my amp ( 5150 peavey)!!!!!!!!!!
my sound with this guitar is dark and stifled... i've tried to put a 1 meg volume pot, but the sound is almost the same.
 i've tried to put some capacitors between the Hot of the bkp and the pot, but the sound has changed very few.
i've tried to lower the pickup from the strings  for cut the bass freq but the distortion isn't the same...
what can i do to have a sound more open ?
i tell you this because i hear the difference when i play this my ibanez and my cort custom shop with a calibrated set of Painkiller and because all my friends tell me after a live performance that there is much difference between this two guitars!
help! :)
-Ibanez rg2570ex with Cpig bridge custom coverd
-Cort KXMP1 custom shop with Painkiller calib set
BigK
Re: the C-pig in basswood dont comes out....
« Reply #1 on: February 17, 2010, 02:13:32 AM »
help! :)
All three Ibanez guitars I have are all quite dark sounding guitars. The only thing I can think of that you havent said youve done is raise the screwpoles nearest the bridge a bit and lower the neck sid screwpoles and that should brighten up your sound.
purist
« Reply #2 on: February 17, 2010, 03:46:58 AM »
try wiring it straight to the jack and see how she goes  :P. I had a C-pig in a basswood with maple neck-thru guitar and i thought it was too dark even though it was maple neck thru.
mesallover
« Reply #3 on: February 19, 2010, 01:13:23 AM »
help! :)
ok i will try! ;D
today i have put a 1 meg pot ( master volume )and a 0,022 mF cap between the pick up and he pot!
well, now the sound isnt dark! but i will try to rise and lower the screwpoles with  a 500K pot!
THANKS!
now the suond
mesallover
« Reply #4 on: February 19, 2010, 01:18:13 AM »
my c-pig is directly wired to the jack because my elecronics configuration is: pick up ( bridge) > master volume> jack
( see my avatar ) :D
Keven
« Reply #5 on: February 19, 2010, 02:48:30 AM »
that's not straight to the jack. the volume pot is still taking away some of your treble.
My BK's:
C-Bomb Set / Blackhawk Bridge
Holydiver Set/ BG50 Set
mesallover
« Reply #6 on: February 21, 2010, 01:32:20 AM »
YES JackBauer
raise and lower the srewpoles works well
THANKS  :D :D :D
