Author Topic: Help me pick out pickups?  (Read 1762 times)
manana12
« on: February 24, 2010, 01:38:47 AM »
Hey im new here and heard great things about BKP so im really wanting to buy one.  I play a lot of metal. im looking for a pickup that can handle solos and also good leads ,djenting and so on here is a link so you get an idea of what kind of music i play.  http://www.soundclick.com/bands/default.cfm?bandID=1035580&content=music
also, i heard good things about coldsweats. what are they good for? im only looking for a bridge pickup.
the guitar i will be putting it in is an ltd viper-50. I dont even know if its worth replacing its pickups. Thanks!
« Last Edit: February 24, 2010, 01:40:32 AM by manana12 »
DimeZakk
Re: Help me pick out pickups?
« Reply #1 on: February 24, 2010, 12:47:48 PM »
The Painkiller would be your Weapon of choice!
...and it's up to you if you want to build a humbucker into a guitar that is worth more than the actual guitar!
James C
« Reply #2 on: February 24, 2010, 03:55:03 PM »
no experience of the PK, but if you want to chuck it in your Viper then go for it, if you get a better guitar in the future you could always load the PK into that.
Formerly "ManOnTheEdge"
manana12
« Reply #3 on: February 24, 2010, 04:05:26 PM »
well i do have an ibanez xiphos an an rg prestige but the viper isthe only one tuned to A
BigB
  • Let's rock !
« Reply #4 on: February 24, 2010, 10:33:15 PM »
Does that guitar sound good by itself ?
manana12
« Reply #5 on: February 26, 2010, 05:41:52 AM »
it souunds ok but im sure a bareknuckle is 10X better than dimarzio activators! Here are the stats for my xiphos
    * Mahogany body
    * Maple/walnut 5-ply neck
    * Wizard II thru-neck
    * Bound rosewood fingerboard
    * 24 jumbo frets
    * 25.5" scale
     Edge III tremolo bridge
    * U.S.A.-made DiMarzio D Activator humbuckers
  Will a painkiller be too bassy for it? I want a pickup that is extremely clear with distorted chords and very tight for djenting. Something like Bulb's sound. Very tight on the low end ( i dont need a lot of it) and great mids. Thanks.
BigB
  • Let's rock !
« Reply #6 on: February 26, 2010, 12:42:00 PM »
Well, the point is that BKPs are AFAICT (from - limited - personal experience and folks wisdom here) very reactive to the host guitar, so while they are indeed great pups by themselves, the result on a cr@ppy axe might not be that pleasing...
Quote
    * Mahogany body
 (snip)
Maple/walnut going-thru neck... Well, may not be that easy to find the matching pup.
Maple is usually very tight & bright, with a fair amount of hi-mids that can easily make the guitar sound harsh, specially with hot ceramic pups (what I experienced with the stock X2Ns on my Vox Custom 24). From what I've seen about walnut, it would be brighter than mahogany, with complex mids and sweet highs - so it could balance the maple - but can easily dampen the sound, specially in the mids, if it's a too dense piece.  And then you have mahogany sides...
With such a combination of woods, I think you really should ask Tim and describe as accurately as possible how the guitar sounds unplugged. Else you may end up with the wrong pup on it.
My 2 cents.
