Author Topic: pcb cleaner  (Read 6686 times)
pcb cleaner
« on: February 26, 2010, 01:52:12 PM »
I just got some of this from maplin and had a squirt to break down some flux.
it worked mostly,
but it left a residue on the pcb, which it claims it isn't meant to do.
its a bit sticky and trying to clean it off is more messy than leaving it.
anyone had a similar experience? can i get away with not cleaning this off? is it conductive?
words of wisdom would be much appreciated. im a bit annoyed with this stuff now. grr
jpfamps
    • http://www.jpfamps.com
Re: pcb cleaner
« Reply #1 on: February 26, 2010, 02:29:39 PM »
My experience of the flux cleaner hasn't been too special either.
I usually clean the PCB with IPA afterwards, but it is bit of a pain.
Maybe we're doing someting wrong!
Re: pcb cleaner
« Reply #2 on: February 26, 2010, 03:02:01 PM »
i thought the spray was an alternative to IPA? oh well.
oh well, not what it says on the tin!
shobet
  • Look into my eye...
    • http://www.dusksky.com
Re: pcb cleaner
« Reply #3 on: February 26, 2010, 03:27:57 PM »
India Pale Ale?
Re: pcb cleaner
« Reply #4 on: February 26, 2010, 03:30:39 PM »
Sadly no...
Isopropyl Alcohol...
SO, still alcoholic, but probably just the next step on from tennents super
Re: pcb cleaner
« Reply #5 on: February 26, 2010, 04:52:32 PM »
Hey
I popped out and got some IPA from a chemist. had to get a 500ml bottle but its still cheaper than getting the same stuff from maplin or whatever.
got a 99p toothbrush too.
my boards look much better now! still some build up from the maplin PCB cleaner but its looking much better.
just left them for a bit now. one was a bit sticky but i guess some of the IPA may still need to evaporate off.
much happier now though
Re: pcb cleaner
« Reply #6 on: February 26, 2010, 06:47:26 PM »
I use 'pre-injection' swabs like they have in hospitals to clean the injection site - they contain alcohol and work a treat.  I figure I'm clean enough not to warrant use of such swabs when I do my twice-weekly injections (health reasons, not scag before anyone has a wise crack).
Re: pcb cleaner
« Reply #7 on: February 26, 2010, 07:11:32 PM »
thats a good plan.
my board looks better.
in the light the surface looks 'worn'? but its just the surface. hard to explain.
the joints are shiny as hell though
impossible
  • Just give up
Re: pcb cleaner
« Reply #8 on: March 02, 2010, 01:59:37 AM »
You did mention scag AND crack though :D
Re: pcb cleaner
« Reply #9 on: March 02, 2010, 11:09:31 AM »
fair point, but I've never even contemplated using that sh*t - life is complicated enough as it is.
