Started by Madsakre, February 27, 2010, 08:47:39 AM
Quote from: Antag on February 27, 2010, 01:30:52 PMIs the RGD the one with direct mounted pickups rather than bezels? If so, you may need to ask for Triangular feet as well.53mm & short legs are the correct specs...
Quote from: Keven on February 28, 2010, 04:24:48 PMQuote from: Antag on February 27, 2010, 01:30:52 PMIs the RGD the one with direct mounted pickups rather than bezels? If so, you may need to ask for Triangular feet as well.53mm & short legs are the correct specs...you can ask for triangular feet?
