Quote from: Alex on February 28, 2010, 07:32:23 PM
My opinion on this is, that it shows which guy is man enough to build his own pedal board and who needs to buy an overpriced pre-made one. 8)
Sorry, that was a bit harsh. But you could still get a cheap Stagg pedalcase for 30£, add an Harley Benton Powerplant (another 30£ or so) and wire it up yourself... for a fraction of the price of the SKB.
http://www.guitarampkeyboard.com/en/stagg/~fx~pedals
Normally I'd have just called you a great big
and left it at that, but I think I'll grace you with an answer as you seem a bit simple and might not get the picture, pun intended.
Yes I'm perfectly aware of all the myriad options that are available when it comes to various boards and power supplies. I applaud you and your manly board making powers. I'll just assume you were clever enough to build a buffer, cable tester, polarity switching and all the other extras that come on the board I've asked about into your pedal board of doom. Does it also make the tea?
However your response doesn't have any bearing to the question I asked so it's pretty much just noise. I'll just ignore you and pretend you didn't say anything. ;)
All the above should be taken with a pinch of salt, as if I really meant to insult you, I would have.
