Author Topic: BKP Crawler installation  (Read 2479 times)
SHROOMPLATOON
« on: March 06, 2010, 09:38:54 PM »
I was finally able to install my Crawler pickups into my Ibanez prestige...I install them according to the specs but i seem to still get the ungrounded buzz. I hate to post a new topic someone asked already but i didnt find anything relevant in the search....After a while i decided to open up the back once again and take everything apart,clean the solder off the pots,the switch and redew it... when I got done this time the volume pot was making a scratchy sound and the ground "humm" went away as long as I was touching the strings or bridge... but the part that baffles me is that when i start to pluck or strum the strings(while my hand is still grounding the guitar) The Ground "buzz" is audible .. ...I hope im just making a simple mistake,, The way i have it set up is very standard , 2 pickups with a 5way switch and one tone and one volume pot....somebody please help
Re: BKP Crawler installation
« Reply #1 on: March 06, 2010, 11:24:53 PM »
You might have a ground loop.  Make sure that there is only one way that the ground can get to the jack socket.  Another thing to check is that you have a ground wire to the bridge.  What pickups were you replacing?  2 humbuckers with a 5 way switch is a PRS set up, but for that to be hum free in the middle settings the magnet needs to be reversed in one pickup.
SHROOMPLATOON
« Reply #2 on: March 06, 2010, 11:43:01 PM »
Before i had a dimarzio tonezone in the neck with a steves special in the bridge...with a 3way switch... the guitar came originally with the stock Ibanez V7 bridge and V8 neck with a 5 way...im actually working on it right now...Im gonna put back the 3 way and see how it works...
SHROOMPLATOON
« Reply #3 on: March 07, 2010, 12:03:19 AM »
if the magnet needs to be reversed is there a way to fix that without a whole ne pup?
« Reply #4 on: March 07, 2010, 03:30:32 PM »
Not really, the was potting would need to be redone.  If you are not using the PRS split coil modes then you should be OK.
SHROOMPLATOON
« Reply #5 on: March 08, 2010, 04:16:21 PM »
Problem apperently was in the 5way switch....Swapped it out and bingo...
