Why is Alnico 3 never used for humbuckers?
Started by Lucifuge, April 06, 2010, 08:41:15 PM
Lucifuge
Not just by BK; most pickup manufacturers use a variety of different magnets in their humbuckers, but I've never seen one with an A3 magnet.
I am assuming there is a good reason, and not just 'vintage PAFs didn't use it, so we won't either.'  Some people, maybe including Tim, must have experimented with this combo and found a good reason why it was inferior to other magnet types in a humbucker, even if it works well in a single coil, so what is it? Too weak or thin?
Edit: While I'm asking stupid questions, maybe I should also ask why you never see Alnico IV single coils?
Brow
Fender in 1 of their newer model strats have a HSS setup and they use an Alnico III in the humbucker.
That's the only 1 I've ever heard of so far though
Antag
It's an interesting question, especially as Tim states "Alnico III is very transparent, low output and clean,sounds great for rounded fat jazz applications-typical of '50s tone.
Alnico IV is probably the best vintage tone IMHO(for humbuckers) and along with II and III was used in the earliest PAFs"
theres been mention of A3 stormy mondays on here before.
I think there are some A3 Mules in one of Tim's, in the gallery maybe?
FenderBender
Skatterbrane Jazzbranes use Alnicu 3 and they sound damn good.  I'm not an expert, but from what I've read, AlniCo 3 is a misnomer since it doesn't contain Cobalt, so it's also called AlNi or AlNiCu (it does contain copper).
Elliot
Alnico III doesn't contain cobalt - but, as I understand it, in the 50s cold war problems meant that the US had a reduced supply of cobalt so magnet manufacturers sold magnet material that was labelled as Alnico but had no cobalt in it.
Quote from: Elliot on October 02, 2010, 10:45:03 AM
Yep - cobalt was used in atomic bombs, so it was scarce as the USA felt the need to build a lot of them in the 1950s and 1960s - think the Russians did too
I've had Alnico 3 mules in a guitar  and yes they sounded a lot more transparent than versions with Alnico 2/4/5
Could still overdrive etc but was more refined /tame- less mids
Here was one that we had them in
I have a set of Alnico III mules for a 12 string.  I can't tell you how they sound though because it is still in construction.  However Tim told me these are what he uses in his doubleneck SG.
Quote from: PhilKing on October 02, 2010, 04:42:56 PM
Will be a good choice !
Tim
We use Alnico III bar in our new Manhattan humbucker size P90s and I have, from time to time, used it in humbuckers where I want a particular control in the high end response, namely on 12 string guitars. Alnico III isn't a misnomer, it is a recognised grade of Alnico.
Tim
exactopposite
#11
I have a set of alnico 3 humbuckers. They are  Giovanni GVH2 pickups. I split up the set and use both of them in the neck position with the alnico 5 version (gvh1) in the bridge position (on 2 different guitars of course).
I do think it's odd that there aren't more alnico 3 humbuckers though. I really like mine. I actually found this post while searching for info on alnico 3 humbuckers.
Bonamassive5150
Hi all,
Tim wound me an AIII humbucker for a neck pickup  back in 05'
i asked for a 'P90' type tone for my EVH Wolfgang,  it was metering out at 7.9K and i think was wound as a VHII (asymetrical coil)
i was after an 'another brick in the wall' tone.  twas spot on! sweet, clear biting, big and bell like.  (really should've taken it out of the guitar before i sold it!)  it was still 'big' enough to match a Crawler in the bridge.
I believe the new Page no'2 Les Paul has an AIII neck bucker in it too.
Quote from: Bonamassive5150 on October 13, 2010, 11:33:56 AM
Hi all,
Interesting. Alnico V and Alnico III-combo. Should bear this in mind. I have a Crawler, like it very much.
ShredHeadJHJ
