Author Topic: Humbucker sized 'Wide Range' pickup!  (Read 17009 times)
Slava
« on: April 09, 2010, 08:55:57 PM »
I'd like to know, if somebody (besides me) intrested in this type pickup. If so - we could ask "Bare Knuckle" to try.
P.S. http://en.wikipedia.org/wiki/Fender_Wide_Range  and http://sixstringbliss.proboards.com/index.cgi?board=searcy&action=display&thread=1153- to lern about 'Wide Range'
« Last Edit: April 09, 2010, 09:25:14 PM by Slava »
Strat - NB-IT-MQ
Lucifuge
Re: Humbucker sized 'Wide Range' pickup!
« Reply #1 on: April 10, 2010, 12:11:46 AM »
I think the problem is that the Cunife magnets they used are no longer made. It might be possible to emulate the sound using some other kind of magnet, I don't know if anyone's tried.
Slava
« Reply #2 on: April 10, 2010, 12:28:05 AM »
This pickup had different from regular Humbucker construction, not only CuNiFe made their sound.
There is some brands who tried and did, but they have mixed user's reviews and no demos
« Last Edit: April 10, 2010, 12:35:37 AM by Slava »
Strat - NB-IT-MQ
« Reply #3 on: April 10, 2010, 01:04:03 AM »
I believe BK have done something with magnetic poles (well, I know they did the pickup, and I think it had magnetic poles) called the Knuckleduster
But
It was an odd shape made for nathan sheperd guitars and wont fit any normal route.
The only pickup I know of thats readily available of the same basic design and is well regarded is the Swinseshead A.M.P. However, it seems swineshead are no more (shame, while BK are the best pickups going, swineshead were like the best kept secret of the UK pickup market - very good sounds).
Maybe, just maybe, you can get something rigged up for you custom.
Failing that you may be able to take heart in the offset winds that BK use as a matter of course to help impart clarity and attack to fat humbucking tones by leaving a few hundred turns in one coil uncancelled, single coil sound (while killing 60 cycle with the rest). All of them are asymmetrical to some degree, maybe the effect can be emulated with a highly asymmetric wind or can be found in BKs most asymmetric winds (like the VHII for example, I believe thats quite heavily offset).
Lucifuge
« Reply #4 on: April 10, 2010, 09:47:25 AM »
If you are just looking for a humbucker that has magnetic polepieces then the Seymour Duncan Stag-Mag does, and Rio Grande also make several pickups like this.
But I'm not sure if they would be that much like the Wide-Range Humbucker, as they just use ordinary alnico magnets like the ones in a standard single coil, and they are not adjustable like the ones on the WRH.
Also, Wizard Pickups make a humbucker called the Brat, which has 3 rod magnets and 3 adjustable screw poles in each coil.
The only one of these pickups I have tried is the Stag-Mag, which I like, but I don't know if it's anything like the WRH as I don't have one to compare it with.
I think the problem with trying to make a pickup like the WRH is that the original cunife magnets had screw threads to make them adjustable, and it is very hard to manufacture alnico rods like this. I've heard of someone doing so, but can't remember where.
« Reply #5 on: April 14, 2010, 08:36:57 PM »
'why' you would want to recreate the Wide Range humbucker is a mystery to me - they're a fairly bland pickup.
what I would like to see though, is a BKP that is the same size as the Wide Range so we can change out those shitety reissue pickups and put something decent in there without the need for a new scratchplate to be cut to accept a standard humbucker size.  of course, it would also need a baseplate with the four mounting screws like the Wide Range too.
I'd be all over a P90 in a Wide Range package (essentially a modified Mississippi Queen).
Slava
« Reply #6 on: April 14, 2010, 09:27:36 PM »
I want it just because it has(d) single coil clarity with humbucker fatness... Fender reissue is nothing like original.
Strat - NB-IT-MQ
« Reply #7 on: April 14, 2010, 09:35:47 PM »
Presumably, with that big cover, there'd be scope to do a split, staggered pickup (like a Precision bass pickup).  Then it could be humcancelling too!  :D
OU818
« Reply #8 on: April 15, 2010, 12:51:16 AM »
I just emailed BKP asking them if they can custom make me something to work in my 72 Reissue Deluxe.
Probably should have jumpe don here first  :D
I have changed the pots in the Tele from the 250k's to 500k's and the difference is rather noticeable.
Failing a set of custom pickups, you could aways try that mod.
Slava
« Reply #9 on: April 15, 2010, 01:05:07 AM »
Thanks, but I need it to be humbucker sized. I know few brands, that doin' this, but some have too big output lewel and some have no clips, and all of them have mixed rewiew (or does not hawe at all).
Plus i don't know if it (i need only bridge) will match BK vintage singles :?
« Last Edit: April 15, 2010, 01:14:40 AM by Slava »
Strat - NB-IT-MQ
« Reply #10 on: April 16, 2010, 10:19:48 AM »
I used to have original 70's Wide Range Humbuckers and had one in the neck position on my '72 Tele Custom - was better than the reissue, but still not amazing - quite neutral/characterless really.  Didn't sound bad, but didn't knock my socks off either.  I used a 1M volume pot with it to get rid of the mud.
More recently I've put a P90 in the neck position of my '72 Tele Custom and that gives single coil clarity with humbucker fatness (as P90s are well known for doing).
Give up on the Wide Range, they're not worth it - go with a P90 or rewound Wide Range - sure Tim could work his magic on it using alnico slugs (along the lines of the Duncan Stag Mag)
Slava
« Reply #11 on: April 16, 2010, 01:05:56 PM »
Yeah. Thanks, HTH AMPS, I think, that only way out for me is to put MQ in the bridge with 2 vintage single coils. :?
Strat - NB-IT-MQ
JakeAC5253
« Reply #12 on: April 17, 2010, 02:40:36 PM »
Does anyone else think that, on paper, these pickups sound a lot like a P-90?
« Reply #13 on: April 18, 2010, 05:41:52 PM »
If you're asking if Wide Range pickups sound like P90s, then no - they sound nothing like P90s.
JakeAC5253
« Reply #14 on: April 18, 2010, 06:49:19 PM »
Not quite, only that they sound similar on paper, the general construction and whatnot.  Other than the magnet type, the wikipedia link makes the pickups sound a lot like Fender's version of a P-90.  At least IMO.
