Author Topic: wiring problem  (Read 5649 times)
horsehead
wiring problem
« on: April 11, 2010, 09:14:14 PM »
ok so I'm re-wiring couple of my strats so that the bridge & middle pickups work off the bottom tone & the neck runs from tone up from there. I've used the following schematic
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=tone_f_bp
but when I've run everything through & tested it, the neck tone seems to be working as a volume control as well....any ideas peeps, I've double checked my wiring, but can't see what the hell I've done. Any ideas greatfully received...as long as they don't include the line "you idiot you've...", as I already know I am
hermetico
Re: wiring problem
« Reply #1 on: April 12, 2010, 01:41:38 AM »
picture?
impossible
  • Just give up
Re: wiring problem
« Reply #2 on: April 12, 2010, 04:51:43 AM »
picture?
+1
Then me and Hermetico can race to figure it out, though I'm sure he'll beat me :D
horsehead
Re: wiring problem
« Reply #3 on: April 12, 2010, 06:43:23 AM »
piccies...sorry about that!
Re: wiring problem
« Reply #4 on: April 12, 2010, 06:53:47 AM »
been a while since ive played a strat.
is the neck tone the middle pot?
if so, one thing that looks different between your wiring and the schematic to me is...
on that tone control it looks like you have the lug soldered to the pot casing, and therefore to ground.
you also have the cap between the centre lug on the other tone, and ground (other pot's casing)
your back end tone pot probably works because as you turn the pot you're still getting frequencies to ground via the cap.
But with the middle pot, you have a direct connection to ground if that lug is soldered to the pot casing.
If i'm right, you need to take off that cap and stick it between the pot casing and the lug you have soldered to the pot casing, and the connect that lug to the centre lug on the other pot.
of course I might be totally wrong.
impossible
  • Just give up
Re: wiring problem
« Reply #5 on: April 12, 2010, 12:50:08 PM »
You're totally right, and this is a pretty common mistake especially when re-using pots. Disconnect that lug from the pot casing but leave the capacitor on it (the lug not the casing) and test it again :)
horsehead
Re: wiring problem
« Reply #6 on: April 12, 2010, 12:52:16 PM »
thanks guys, worked a treat
hermetico
Re: wiring problem
« Reply #7 on: April 12, 2010, 04:19:01 PM »
picture?
+1
I had no time.
LOL.
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
Re: wiring problem
« Reply #8 on: April 12, 2010, 05:16:43 PM »
Russian PIO?
I've got a few of those myself, I like them more than Sprague Vitamin Qs.
I see a rainbow rising
Look there on the horizon
And I'm coming home
