Started by Stevepage, April 13, 2010, 03:47:17 PM
Quote from: Frank on April 14, 2010, 06:22:54 AMI occasionally buy a lottery ticket with the numbers 10, 13, 17, 26, 36, 46. Is that sad?
Quote from: Philly Q on April 14, 2010, 08:07:16 AMQuote from: Frank on April 14, 2010, 06:22:54 AMI occasionally buy a lottery ticket with the numbers 10, 13, 17, 26, 36, 46. Is that sad?Just as much chance of winning as anything else!
Quote from: FELINEGUITARS on April 14, 2010, 09:42:30 AMQuote from: Philly Q on April 14, 2010, 08:07:16 AMQuote from: Frank on April 14, 2010, 06:22:54 AMI occasionally buy a lottery ticket with the numbers 10, 13, 17, 26, 36, 46. Is that sad?Just as much chance of winning as anything else!Not as bad as using the number sequence from lost
Quote from: Will on April 14, 2010, 12:03:28 PMQuote from: Philly Q on April 14, 2010, 08:07:16 AMQuote from: Frank on April 14, 2010, 06:22:54 AMI occasionally buy a lottery ticket with the numbers 10, 13, 17, 26, 36, 46. Is that sad?Just as much chance of winning as anything else!1,2,3,4,5,6?
Quote from: Frank on April 14, 2010, 10:14:39 AMI reached a point with Lost where (a) I didn't know what was going on(b) if I did know what was going on, I wasn't sure why it was going on and(c) I didn't care any more
Quote from: gingataff on April 14, 2010, 02:33:31 PMI'm not sure if you've already seen it but there's a new type of Jazz III out with a Stickle Brick type grip on it. I'm waiting for the XL version though.
Quote from: Stevepage on April 14, 2010, 02:35:17 PMQuote from: gingataff on April 14, 2010, 02:33:31 PMI'm not sure if you've already seen it but there's a new type of Jazz III out with a Stickle Brick type grip on it. I'm waiting for the XL version though.Yeah the Max Grips, I was gonna try them or try and find the Carbon Fibre Max Grips (which are impossible to find), but the grip on the EJ's are just fine. They're a touch bigger too
