Author Topic: Would someone explain this  (Read 1869 times)
manana12
« on: April 24, 2010, 06:31:16 AM »
Can someone explain this please? Thses are the options for ordering
1. Position:     This is get im doing the bridge
2. Spacing:    How do i measure this?
3. Coil Colour:    Blue
4. Conductor:    Not surewhat this means
6. Leg:    Dont understand what this means
7. Gold Pole Screws/Slugs: dont understand what this means
Antag
Re: Would someone explain this
« Reply #1 on: April 24, 2010, 07:49:51 AM »
Sure, here goes:
Yeah, hopefully you know whether you want a pickup for the bridge or neck position (or a calibrated set if you want both)
This applies to the bridge pickup only. Get a ruler or some calipers & measure the distance between your top & bottom strings over the bridge pickup - which ever out of 49 & 53mm is closest to that measurement is the spacing you should choose
Yep. this is fairly self-explanatory :)  The colour of the plastic bobbins on the top of an uncovered humbucker.
This is the wire.  If you want to have the option of coil splitting, or series/parallel wiring, choose 4.  If your not sure choose 4 anyway because you don't have to use those options.  If you have a gibson & want to wire it identically, then you can choose Braided 2.
This is the length of the mounting bracket.  If the you're not sure, choose the short one as many guitars don't have a deep enough rout for the long one.  What is your guitar?  Does it have a pickguard or mounting rings or is the pickup direct mounted?
This is the 2 rows of 6 pole pieces that will be directly under the strings when you have installed the pickup.  You can choose to have them in a gold colour or go with the stock chrome colour.
manana12
« Reply #2 on: April 24, 2010, 02:15:54 PM »
Thanks for the info. My guitar is an ibanez Xiphos http://www.ibanez.com/ElectricGuitars/model-XPT700
I dont think i will need the 4 wires since i just want two humbuckers no need for series/parallel. Should i choose the short or long leg?
