SPLAWN AMP has arrived!
Started by TwilightOdyssey, December 02, 2005, 03:33:40 AM
My Splawn Quick Rod arrived via FedEx today! I didn't have a guitar at work today, strangely enough, so I will be bringing one in tomorrow. I also didn't have time to even put the valves into the amp or even turn it on. Tomorrow I will get around to doing the most basic assessment and will report back.
What can I tell you about the amp?
First of all, it was packed magnificently. The amp itself was wrapped in shrinkwrap with all the corners and edges protected by styrafoam or thick cardboard. This was placed in a thick cardboard box. That entire box was floated inside another outer box. The entire thing arrived in mint condition however, without even a scuff mark on the outer box.
The amp itself looks A M A Z I N G!!! Build quality is phenomenal!
This is a stock photo of the amp:
The front panel, from left to right has the power and standby switches, which are these industrial toggles like you would see on a Roccaforte, not rocker switches. Next to that are all the controls for the gain channel: EQ, gain, channel volume, and boost. (More on the boost in a moment) All of the knobs are black vintage against white plexiglass. Next comes the 3 position voicing switch, labeled First Gear, Second Gear and Third Gear. The clean channel has it's own EQ. On the far right are the master volume and single input.
The fit and finish on the amp are INSANE! The tolex is beautifully wrapped, accented with white piping.  The grille area is a large piece of white plexiglass with the Rising Sun graphic. The chasis is topped off with a leather strap handle with chrome (or stainless steel) ends. Class!
The back of the chasis has a wire mesh over the top portion where you can see the valves and the massive transformers. (The amp weighs about 60 lbs). The valves are packed seperately inside the tube cage. The rear panel has two inputs for the footswitch, two outputs for loudspeaker attachments, a DI out, FX loop, 1/2 power switch, and IEC mains jack.
Packed seperately is the metal footwitch, which has an elegant curved top, which is then covered with a white plate that matches the panel on the amp. Again: CLASS! There are 3 switches on it: Clean, OD, and Boost.
The boost is a pure volume boost for the OD channel, not another gain stage. So, all you do is set your rhythm volume, dial in the amount of boost you want for your solos, and voila! You are done! No more running a boost pedal through the FX loop!
Scott Splawn promised me the amp in 4 weeks, and he delivered it in 4 weeks to the day. Everything about the amp just screams quality and attention to detail.
Tomorrow: Pics and the first run through! Watch this space for details!
wixomwhat
that amp looks so badass with the Rising Sun!
bucketshred
This thread is useless without CLIPS!
I really want to hear this amp in action, I need to get over to the State to try out some of these lovely amps! (I still need to try out a Matamp too!)
Andy!
GREAT GOOGILY MOOGILY!
I'd love to have one of those. Especially because they seem to be betterthan the the Roccafortes.
Can't wait for the clips.
Davey
the last pic is blurry. now you must send the amp to me so i can shoot a better picture
Quote from: Daveythe last pic is blurry. now you must send the amp to me so i can shoot a better picture
:lol:  :lol:  :lol:
+1!
It might take some time to make a proper picture tho. Waiting for that special piece of sunlight that would make the picture perfect. :twisted:
willo
Nice amp!
But...
Hypothetically speaking, would it be possible to have the 'Middle' at 9 o clock and the 'Treble' at 3 o clock for instance, or do the chickenhead knobs bang into each other? :?
Looks like a really nice amp though, bet it sounds as nice as well!
chrisola
sweet!
we need clips damnit.... :wink:
something VERY cheesey and 80s 8)
I'd be happy to make some soundclips with that amp. :wink:
Willo brings up a valid point - I'd guess that theres no problem though! if theres was it'd be disgraceful
Quote from: willoHypothetically speaking, would it be possible to have the 'Middle' at 9 o clock and the 'Treble' at 3 o clock for instance, or do the chickenhead knobs bang into each other? :?
Just checked that. The answer is no, they all fit fine.
Peterku
That amp looks really nice! Congrats! 8) What does the Solo knob do? Is it the Boost you wrote about?
ooooo I'm so excited about clips!!!! :lol: its gonna kick assssssssss :wink:
Quote from: PeterkuThat amp looks really nice! Congrats! 8) What does the Solo knob do? Is it the Boost you wrote about?
Yes, that's the solo boost.
