Painkiller Trilogy Suite <-> 1 Volume & 1 Push/Pull Tone
Started by austexcap, April 30, 2010, 03:09:13 PM
austexcap
I am replacing the pickups in my Caparison Dellinger (HSS) with the Painkiller Trilogy Suite and need a little help. There is one volume and a push/pull tone that when pulled splits the humbucker and what used to be a single coil sized humbucker, the switch is a 5-way.
I've got the Painkiller wired up correctly but how would you guys recommend wiring the singles?
like this:
http://www.seymourduncan.com/images/support/schematics/HSS_1v_1t_5w.jpg
but with red to switch, black/bare to back of pot and white and green would be taped off - instead you will send them to the switch
so the green and white wires from the bridge p-up can then be wired to the push/pull for the coil split - looks like this
http://cracklecdn-zoovy-1.simplecdn.net/img/guitarelectronics/W550-H420-Bffffff/W/wd1h0010_01.jpg
