Author Topic: What happens if...  (Read 4143 times)
What happens if...
« on: May 05, 2010, 11:51:28 AM »
... you plug a 9v pedal into a 12v adapter?
Does it go boom, or blow out a bit of the circuit?  Or can most tolerate the extra power?
Mark.
tomjackson
Re: What happens if...
« Reply #1 on: May 05, 2010, 12:23:58 PM »
I'd say it depends on the pedal, some have protection circuitry, some don't.  Some pedals can run from 9V to 18V happily and are designed to accept greater voltages.
I think most would be okay but some would die :(
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
« Reply #2 on: May 05, 2010, 05:02:22 PM »
I'm hardly an expert but I think it'll mostly depend on the value of the electrolytic caps used. Most small ones are rated up to 16v so you *should* be fine with 12v, but be wary of 18v power supplies unless you know what's inside the box.
Often using a higher voltage supply can give more headroom, but if in doubt use 9v.
I see a rainbow rising
Look there on the horizon
And I'm coming home
jpfamps
    • http://www.jpfamps.com
« Reply #3 on: May 06, 2010, 04:23:51 PM »
The advice given above is correct for most pedals as the components should be able to tolerate the higher voltage.
I would be wary of using a higher voltage adaptor in a digital pedal (although there wouldn't be much point).
