November 20, 2026, 08:10:38 AM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Tech
Missisippi Queen Neck wiring??
Started by Transcend, May 08, 2010, 10:35:54 AM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
Transcend
Guest
Logged
ive always dealt with either 4 conductor or the bkp braided 2 con.
This is just bare, black and white
any idea on what i should do as the included schematics are for the braided and 4 con which is no help to me
cheers
Light Heavyweight
Logged
Re: Missisippi Queen Neck wiring??
#1
May 08, 2010, 11:20:33 AM
I'm guessing, but bare and black to ground, white to hot.
Then if it's out of phase with your bridge pickup, swap white and black. The bare wire will always go to ground. :D
Transcend
Guest
Logged
#2
May 08, 2010, 11:21:33 AM
thanks alot philly ill check this? how will i know if its out of phase?
Light Heavyweight
Logged
#3
May 08, 2010, 12:02:57 PM
By the sound - if the pickups are out of phase the middle position will sound much thinner than bridge or neck, a sort of "hollow" tone with very little bass. It's a pretty cool sound actually, you might like it! :)
Transcend
Guest
Logged
#4
May 08, 2010, 01:39:58 PM
right i have the MQ working fine but now in the bridge position the MQ is also active and i have no idea whats gone wrong.
Ive double checked all connections and nothing seems to be connected together
MQ is on position 3 and mm is on position 1 with the central going to the first tag on the volume pot
Light Heavyweight
Logged
#5
May 09, 2010, 03:02:04 PM
Any chance you could take a picture of the wiring (or do a diagram)?
I'm assuming it's two pickups with shared volume/tone controls?
Transcend
Guest
Logged
#6
May 09, 2010, 11:51:42 PM
I've figured out what it is.
Theres a small gap where the contacts are in the casing for the switch (3 way blade) and a bit of solder has dropped inside and is bridging the contacts.
Ill go pick up another switch tomorrow.
Thanks for all your help Philly
Light Heavyweight
Logged
#7
May 10, 2010, 12:55:04 PM
No problem, hope the new switch does the trick.
Transcend
Guest
Logged
#8
May 10, 2010, 01:15:27 PM
It does its all working fine now i have a new problem. The screws that came with the ibanez are too wide for the switch but its easy to get new screws.
Thanks again.
Print
Go Up
Pages
1
User actions
Forum Ringside
Tech
User actions
Print
