Just borrowed an Blues Deville for a gig tonight, just cranked it, it's loud but if you strum and let it ring it kind of fizzes away.
I presume that would be something to do with the power valves? I've swapped two of the preamp vales (on the RHS as you look at the amp from the back) to see if it was V1 but the problem is the same. I'll try moving them round to V3 as well just to make sure it is none of the preamp valves.
any ideas?
