Author Topic: Fulltone Mini Déja-Vibe  (Read 2004 times)
viking
« on: May 24, 2010, 03:53:16 PM »
Hi!I have an opportunity to buy a Fulltone Mini Déja-vibe.I always wanted to try one but found it too expensive..Until now..This time,the price is ok but i won't have a chance to try it first..What do you think about it?Tell me everything  :lol:
Andrew W
Re: Fulltone Mini Déja-Vibe
« Reply #1 on: May 24, 2010, 08:19:12 PM »
I really like mine a lot and it's one of the pedals I use most, it's certainly my favourite Univibe pedal.  The construction is rock solid and whilst the controls are minimal I find I get everything I want from it.  For me, as I don't tend to change the speed of the effect on the fly, the version with the pedal is not worth the extra expense.  For sound examples listen to any recent Robin Trower record as he uses one a lot.
viking
« Reply #2 on: May 25, 2010, 01:19:46 AM »
Thanks,AndrewW  8)!Is it a simple 9V-powered pedal?
Andrew W
« Reply #3 on: May 25, 2010, 07:18:09 AM »
No battery, you have to use wall power.  It is 9v but it draws a lot of current I believe hence a 9v battery not really cutting it.
jpfamps
    • http://www.jpfamps.com
« Reply #4 on: May 25, 2010, 10:39:57 AM »
I've got one of the older, mains powered Deja Vibes and I really like it, although it only gets used occasionally at home.
Incidenatlly. the power supply in the Deja Vibe actually steps the voltage up to 18 VDC, like the original.
viking
« Reply #5 on: May 25, 2010, 10:57:46 PM »
Ok,i 've got it :D! Now,i know why they call it the "Mini Deja-Vibe"... :) It's surprisingly small & compact!It's a really beautiful pedal!There was no power supply,so,i used a regular 9VBoss PSA transformer.I only tried it 10-15 min. at low volume but i'm already very pleased by the sound !I used it in front of the amp but,when i set the MDV's volume too high ,i can hear radio interferences...very vintage  :( I will try in the loop tomorrow and see how it goes...
