Help me understand!
Started by dellinger88, June 05, 2010, 01:03:30 PM
dellinger88
Hey, thinking about getting a Warpig set in my Caparison Dellinger... but im sorta lost with all the options/specs you can choose with these pickups  :oops:  .. can anyone explain them a little better? .. heres some pictures of my guitar.. im trying to work out what i need to get in order for them to install correctly... any help would be awesome thanks!..
the pot is a CTS 500K for volume, 3 way toggle ...
Conductor - 2 or 4. 4 comes in effect as 2. You want to order 4 and wire it in series, which it will arrive ready to do. 4 allows other switching options later and keeps maximum resale value. 2 is series (normal humbucking) only. The pickups you have in there are 4cond, so it should be easy.
Leg length - the length of the brackets that the pickup is screwed in with. You want short.
Spacing - the distance from low 1st to 6th pole. You want standard/non-trem.
P.S. 456s are great bridges, good choice.
I have a sneaky feeling that a 456 is trem spaced actually....I should know, I have one on one of my main guitars...but I dont know. Worth checking. 50mm = standard, 53= trem. Google is your friend.
dellinger88
Thank you! just what i was looking for  :D
dellinger88
Quote from: MDV on June 05, 2010, 01:09:32 PM
you are correct its 53mm .. thanks for all your help  :wink:
