Author Topic: DIY Pedals where to begin?  (Read 4981 times)
mikeshaug
« on: June 07, 2010, 02:28:04 AM »
Hi there. Im new to the forum here. I have recently developed an interest in pedal building. I want to know where I should begin. My understanding of this stuff is pretty limited, so any input from you guys would be appreciated. I was told that a tube screamer would probably be the best starting point for pedal building.
As far as tools I have some stuff but should probably buy more. What kit to you guys is a good starting point, and what tools should I have. Thanks
Re: DIY Pedals where to begin?
« Reply #1 on: June 07, 2010, 03:40:08 AM »
A good soldering Iron will be really helpful.
you can get some decent budget soldering stations.
also, helping hands (croc clips on a stand with a magnifying glass) might help.
some stuff for cleaning your soldering iron. there are different products.
it worth getting some good wire cutters.
maybe a small wire stripper.
check out BYOC
http://www.buildyourownclone.com/index1.html
they have some good kits, even for starters. They sound good and they have good instructions.
I find this site helpful too
http://www.beavisaudio.com/
It has a 'soldering 101' and in the tech pages some useful notes on various things like switches and so on. good once you're started and thinking about modding what you've built already i guess.
A fuzz might be easier than a screamer.
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
« Reply #2 on: June 07, 2010, 04:02:06 AM »
If it's your first time start with something simple like a fuzz.
A TS is much more hassle and realistically you'll need a PCB whereas you can make a fuzz on perfboard.
I've made about half a dozen pedals (several more yet to be finished) and didn't use a kit for any of them, I just used DIY books (admittedly not a huge choice available) and websites such as freestompboxes.org, beavisaudio.com,  Fuzzcentral, etc.
Quite a few members of this forum have used kits though so I'm sure they can give you some good advice.
As for tools I'd say a couple of good soldering irons (I like the ones with changeable tips so you can use a big one for soldering jacks and a small one for PCBs), good solder (I use Kester 44), a drill, reamer and goggles (for making cases which is the least fun part of it), wire strippers/cutters, helping hands, heatsinks, desoldering braid, shrinktubing and of course... a multimeter!
I see a rainbow rising
Look there on the horizon
And I'm coming home
Deadstar
« Reply #3 on: June 07, 2010, 12:51:21 PM »
Yeah a screamer is maybe a little complicated for a first build but fuzz is fairly simple.
Got a link here for a ZVex SHO boost though which is also quite easy to do:
http://thepedalbuilder.com/?paged=2
"The secret to creativity is knowing how to hide your sources." -Einstein
tekbow
« Reply #4 on: June 07, 2010, 01:02:28 PM »
And good luck as well with the builds  :D i'm way to intimidated by electronics to even try, so fair play to you
marauder
« Reply #5 on: June 07, 2010, 02:10:27 PM »
This page has all the pedals that Juansolo and I have built in order of construction.
He does the wiring, and I do the painting (and debugging when they dont work - he really hates that).
It was perhaps a little adventurous of him to get a BYOC OD-2 as the first kit, but it does work fine.  They tend to get neater and more complex as time goes on.
http://www.juansolo.demon.co.uk/geetah/stompage.html
« Reply #6 on: June 08, 2010, 11:53:14 AM »
I'm thinking about building a fuzzrite clone for those spaghetti western tones.
Anyone have a 'buildsheet for dummies'?
sjwebb90
« Reply #7 on: June 08, 2010, 12:11:52 PM »
Another couple of sites to consider are:
http://www.generalguitargadgets.com/
http://www.tonepad.com/
Hard to find pedal parts plus the usual stuff can be found at Smallbear and they ship to the UK.
http://www.smallbearelec.com/home.html
marauder
« Reply #8 on: June 08, 2010, 10:36:22 PM »
mikeshaug
« Reply #9 on: June 09, 2010, 02:52:14 AM »
ok i am on BYOC what fuzz should I buy? thanks guys
« Reply #10 on: June 09, 2010, 10:41:25 AM »
Thanks Marauder!
marauder
« Reply #11 on: June 09, 2010, 11:51:51 AM »
Sign up to the BYOC forum, there's load of good advice there.
mikeshaug
« Reply #12 on: June 10, 2010, 12:32:06 AM »
I am thinking maybe the leeds
marauder
« Reply #13 on: June 10, 2010, 09:54:56 AM »
Possibly the most complex fuzz ever, more than 10 components in that one.  Just dont rush it as its your first build.
mikeshaug
« Reply #14 on: June 11, 2010, 02:49:31 AM »
bought tne octavia fuzz
