Author Topic: Installing Nailbombs into a LP  (Read 1683 times)
machinestead
« on: June 24, 2010, 10:52:19 AM »
Hi There!
This is my first post, so be gentle etc.
Been looking at a set of Nailbombs for sometime now, finally took the plunge and bought a set. They should be here tomorrow, and I'm just wondering, is there a wiring diagram knocking about the web somewhere, or any instructions included in the box?
Also, I've read about being able to coil tap them, is that completely necessary, and do i need to buy anything extra to wire the coil tap in?
Apologies if these seem like silly questions. I've only ever installed EMG's before, and I screwed that up lol.
Thanks for any replies in advance
Tellboy
Re: Installing Nailbombs into a LP
« Reply #1 on: June 24, 2010, 12:34:04 PM »
A wiring diagram is included with the pickups (plus a set of strings and pick) and is normally a simple replacing like for like. Coil "splitting" is only possible if you ordered the 4 conductor option and you will need a push/pull tone control to allow you to ground one of the coils in each pickup - wiring diagrams are readily available. (Coil tapping is where you disconnect some of the wind on a single coil -  coil splitting is where you switch out one of the two coils of a humbucker pickup)
« Last Edit: June 24, 2010, 12:35:48 PM by Tellboy »
machinestead
« Reply #2 on: June 24, 2010, 12:55:35 PM »
ah wicked thanks :)
I wasn't aware of the difference between tapping and splitting. Cheers for explaining it!
