Author Topic: Guiatar speaks  (Read 4698 times)
Transcend
Guiatar speaks
« on: July 10, 2010, 05:36:28 PM »
Right im looking to upgrade the speaker in my tsl
and there is a switch for 8 or 16ohm
is this just for use with a 2x12  or does it mean i can use 8 OR 16 as the internal speaker??
I'm asking because the input from the internal one says "internal speaker 16ohm"
and i was wondering if that was just because the g12h80 is a 16ohm speaker or if it has to be a 16ohm to replace it.
If that made any sense.
Thanks
Frank
Re: Guitar speakers
« Reply #1 on: July 11, 2010, 03:43:35 AM »
You can put an 8 or 16 ohm speaker in there but remember to set that switch accordingly or you may risk damaging the output tubes (or more expensively, the output transformer!)
Transcend
Re: Guiatar speaks
« Reply #2 on: July 11, 2010, 07:47:10 AM »
I thought as much and which jack would i use for it? the one that the internal speaker is already connected to or the extra one that i presume is for an extension cab?
Sorry if these questions are a bit stupid sounding i just dont want to risk damaging anything.
Re: Guiatar speaks
« Reply #3 on: July 11, 2010, 10:45:49 AM »
The same one it uses now  :)
d1dsj
Re: Guiatar speaks
« Reply #4 on: July 11, 2010, 07:30:21 PM »
I would replace it with a 16ohm speaker. That way if ever you want to use another extension cab, but one that is also 16ohms (doesn't matter if it's a 1 x 12, 2 x 12 or 4 x 12 as long as it's also 16ohms) you just set the amp to 8ohms ASSUMING YOU WILL BE USING THE INTERNAL SPEAKER AT THE SAME TIME. Hope this helps?  :)
Transcend
Re: Guiatar speaks
« Reply #5 on: July 11, 2010, 08:21:11 PM »
I am going for another 16ohm
what i was planning on doing was using just the internal atm
then using a 2x12 for live
i didnt know you could use both at the same time that is pretty cool.
Thankyou for the information that was really helpful
Frank
Re: Guiatar speaks
« Reply #6 on: July 12, 2010, 10:10:39 AM »
ah right, didn't realise you were going to use TWO speakers ... if you have a 16 ohm and you add a 16 ohm speaker in parallel then the impedance is 8 ohms
don't use an 8ohm cab in parallel with an internal 16ohm or you'll end up with 5.333 ohms and you can't set that impedance on the amp
Frank
Re: Guiatar speaks
« Reply #7 on: July 12, 2010, 10:13:16 AM »
if I get time this evening I'll do you a diagram of the wiring options and impedance settings
Transcend
Re: Guiatar speaks
« Reply #8 on: July 12, 2010, 03:19:03 PM »
well at the moment i am just going to be using the internal speaker so theres no need.
the extension cab was going to be something that came later when this new project gets going.
Thankyou anyway
Frank
Re: Guiatar speaks
« Reply #9 on: July 12, 2010, 04:31:43 PM »
I did this for you anyway!
http://kineticnorth.com/impedance.htm
Transcend
Re: Guiatar speaks
« Reply #10 on: July 12, 2010, 04:43:02 PM »
Wow that is great thanks.
Ill keep that bookmarked.
andymac
Re: Guiatar speaks
« Reply #11 on: July 17, 2010, 09:27:16 PM »
2 Les Pauls 1 Mule Bridge 1 Black Dog Bridge.  Feline Lion 2 Crawlers, Tele - Piledriver Bridge and Boss Neck
HairyChris
Re: Guiatar speaks
« Reply #12 on: July 18, 2010, 11:37:47 AM »
According to Mesa, if you do have mismatched speakers you should pick the setting below the total resistence (so for 5.333 use 4).
I can vouch for how output transformers melt themselves if you do it wrong.
ailean
Re: Guiatar speaks
« Reply #13 on: July 18, 2010, 01:51:03 PM »
I've only owned one combo amp, but with that one when I plugged in the external cab the internal speaker was switched off internally, don't know if that's the case with the JVM though.
Gibson LP std + Nailbomb set
