Author Topic: OK, what have I done this time! (Wiring question)  (Read 5350 times)
horsehead
« on: July 17, 2010, 10:40:54 PM »
I always seem to make a mistake somewhere & can't figure it out, so I'll add to my stupidity by posting my latest c--k-up. I thought I'd got it done right (typical of me) for vintage wiring, but I'm getting nothing through when I touch the pickups with a screwdriver....can't figure it
Re: OK, what have I done this time! (Wiring question)
« Reply #1 on: July 17, 2010, 11:12:27 PM »
It looks fine from what I can see.
Have you checked the selector switch and output jack?
horsehead
« Reply #2 on: July 18, 2010, 06:03:47 PM »
Measured the pickups resistance on the wire when they aren't soldered to the pots & getting the correct reading (11k & 12k), but when soldered they are giving off only about 5.5....really has got me stumped
« Reply #3 on: July 18, 2010, 07:22:09 PM »
Very odd.
You're getting signal out via a cable, yes?  That's how you've got the 5.5k readings?
You've got a lot of braided cable there, make sure none of it is touching the hot signal - pickup connections, switch connections, hot jack output etc.
horsehead
« Reply #4 on: July 18, 2010, 09:24:00 PM »
finally sorted it, it was part of the braid on the hot end of the jack, thanks for the help Dave
Andrew W
« Reply #5 on: July 18, 2010, 10:03:04 PM »
Glad you sorted your problem. I always find that the braided wire bites me in the bum. I got sufficiently distrustful that when I put the Mississippi Queen into my Tele I soldered some regular push-back cable onto the braid and then covered the rest of the braid with shrink wrap to prevent myself from another grounding problem. I could then used the soldered on cable to connect up as you would with regular wiring. If I were better at soldering and electronics this wouldn't be a problem but until I become less ham-fisted this is the kludge that works for me.
« Reply #6 on: July 18, 2010, 11:12:42 PM »
ooh - you got the russian caps in there - hope you like them
« Reply #7 on: July 19, 2010, 12:41:53 AM »
Kerrching!  :D
No probs mate, glad you got it sorted!
horsehead
« Reply #8 on: July 21, 2010, 06:21:30 AM »
what....don't say it like that! You got me worried now!
