Hmmm- dont have a diagram per se
I tend to end up doing the wiring from first principles each time
The mag flip will allow you to still have the screw pole at the neck and bridge positions
In BKP humbuckers (normally)
screw coil is south polarity and has black and white wires at coil ends
slug coil is NORTH polarity and has red and green wires at coil ends
If my memory serves me correctly - you will require to do this to give inner coils on together humcancelling and in phase
Flip neck magnet so slug coil is south in neck pickup
Bridge pickup
red = hot - goes to switch on the output side
black = earth - goes to pot
green + white are coil tap point and go to other side of switch that connects to earth - note that coil tap wires go on opposite orientation to hot wire
Neck pickup - gets it's wiring turned inside out
green = hot
white=earth
red + black =coil tap
if this sounds thin in middle position , reverse neck green and white
I found this old diagram I did of the switch but I may have the hot and earth wires reversed on the neck pickup
Test for yourself to get the right result
