Bugera V22 Demo
Started by choucas09, August 06, 2010, 12:41:50 PM
choucas09
Clean, Crunch and gain clips of my V22. Guitar was a JJ Retro. First two on the neck BKP90 the last on the alnico 2 Mule at the bridge.
http://soundclick.com/share?songid=9492129
http://soundclick.com/share?songid=9492140
http://soundclick.com/share?songid=9492142
maverickf1jockey
Sounds really nice, Kudos!
tomjackson
That sounds SO GOOD man! All thumbs up!
choucas09
 It cost me £249 delivered. I've got five pedals which, in real terms, cost more than this amp and it very easily represents my best musical bargain in 43yrs of playing. Everything works so well and you can make subtle or major changes to your sound with ease. There are also three ways to change the overall character of the amp. There are two inputs Normal and Bright which are markedly different from one another. You can switch from Pentode to Triode ditto the above. Then there's the mid boost which does what you'd expect which with the gain up puts you in Santana territory. It also has a series effects loop which is very handy as I put my Jamman in and can record a backing in a clean sound then overlay something on the gain channel. It's also delightfully light at just 38lbs.
I think the main thing about this amp is that it is harmonically rich at any setting and has a quality that I haven't experienced before in an amp namely "charm". It really makes you want to play.
