Author Topic: Humbucker suggestions for Parker NItefly M  (Read 3005 times)
nyne
« on: August 11, 2010, 05:06:42 PM »
I have a Parker Nitefly M. It is my only guitar and i want  a tone upgrade from it.
Right now i have a Duncan Distortion in the bridge and Duncan Jazz in the neck with coipl tap option.
I play everything from Heavy Rock clean slow blues.
For some reason my Nitefly falls short of being a hi end instrument even though it looks and feels gorgeous.
i was wondering if Bare knuckle Pickups might be the answer.
I have totally bypassed the Piezo system and its just a Hum/Hum guitar with coil tap.
My needs: Bridge--Hot enough for metal, Pinch harmonics, clarity, warmth, big sounding.
Neck needs is where i always fail. I'm trying to get too much out of one guitar. I'd like a smooth soloing tone for hi gain, but i also want glassy , big clean tones. Neck hum in single coil mode should be stratish and i would prefer to coil tap the outer coil---closer to neck joint. Am assuming this will be closest to strat neck tone ???
Maybe i am being unrealistic. But i feel there might be some hope here.
Please advise.
Thanks
Nyne
Here are the specs of the instrument:
Body Wood - Mahogany
Construction - Solid one piece
Finish - Satin, oiled
Bridge - Parker custom cast aluminum vibrato bridge, Stainless steel saddles
Vibrato System - 3 spring, 3-mode step stop: fixed, bend down only or floating
Neck Wood -Mahogany
Neck Design - Solid one piece with carbon-glass-epoxy reinforcement
Neck-Body Joint - True bolt-on with half-rounded precision joint
Scale - 25.5"
Frets - 22
Fret Material - Hardened stainless steel
Fret Size - .052" high, .103" wide
Fret Board - Carbon-glass composite
Fretboard Shape - 10"-13" conical form
Neck Shape - Width: regular, Thickness: fat
Nut - GraphTech
Nut Width - 1.68"
String Spacing - Bridge: 2.14", Nut: 1.38"
Truss Rod - Custom design lightweight steel
Tuners - Sperzel locking
Weight - 6 1/2 lbs
Re: Humbucker suggestions for Parker NItefly M
« Reply #1 on: August 11, 2010, 09:15:06 PM »
sounds like a holy diver set
that's exactly how I would describe the bridge pickup
recorded a raw video a few years ago:
http://www.youtube.com/watch?gl=BR&hl=pt&v=T1RafxMYU5w
didn't try the neck model, though, but I'd expect the tone you described after checking others reviews and clips
but maybe you would enjoy a mississippi queen on the neck position
