Author Topic: Modding Pickup Lugs  (Read 4414 times)
Dazza1004
Modding Pickup Lugs
« on: August 14, 2010, 03:10:41 PM »
Has anyone modded the lugs on a BKP humbucker ?
I have lost patience with the Aldrich set in my Suhr, I have a HD set but the lugs are square and I need triangular as the suhr is top mounted.
I'm sure it's not a big job but I am a bit worried I may screw it up and end up with a set of useless BKP's....
cheers
Re: Modding Pickup Lugs
« Reply #1 on: August 14, 2010, 05:25:33 PM »
yeah, just carefully trim them down.   worst that can happen is you break it - but even if that happens tim will put a new base on for a very reasonable price
if you are carefull you wont have problems
i usually snip till close, then cover the p-up with masking tape before filing it neater.. then clean all the metal bits off the tape before removing it
Dazza1004
« Reply #2 on: August 14, 2010, 06:12:58 PM »
thanks Wes.
« Reply #3 on: August 14, 2010, 10:10:12 PM »
I've done exactly the same - not difficult at all and turns out fine.
Dazza1004
« Reply #4 on: August 15, 2010, 07:07:44 PM »
cheers Phil, I'm working up the courage to give this a go
