Author Topic: First time swapping pickup need help!  (Read 5601 times)
MiloF
« on: August 18, 2010, 02:41:32 PM »
Hey guys,
So this is my first pickup change Ive done myself. Im fully confident in my soldering skills but I'm getting confused with a few things.
Its going into an Ibanez RG so tone, volume and 5 switch.
Im putting in a Miracle Man 4 conductor.
HSH configuration
What I do get is -
Red goes to pot tag
Black goes to the back of tone? pot as a grounding
What I'm battling with -
Which tag am I soldering it to for the bridge position
On the FAQs of BKP it mentioned where the red, black, white and green go. But theres a bare wire.
Where does this one go?
And thats all.
Which tag and bare wire placement.
Thanks in advance guys.
« Last Edit: August 19, 2010, 02:45:35 AM by MiloF »
Re: First time swapping pickup need help!
« Reply #1 on: August 18, 2010, 05:27:54 PM »
Bare wire goes to the back of the pot with the black wire.
The red goes to the 5-way switch
The green and white go together, also to the five way switch
Basically, they attach where the old wires did!
MiloF
« Reply #2 on: August 19, 2010, 02:41:50 AM »
The green and white same position as where the red is?
I thought theyre just left alone soldered together because they came heat shrinked together
« Reply #3 on: August 19, 2010, 08:23:56 AM »
Did your Ibanez have a coil-split in the bridge+middle position?  If it did, you'll need those Green+White wires.  If not, they can stay taped together.
If it did have a split, the Ibanez bridge pickup probably has three wires (rather than 4 like the BKP), two of which are connected to the switch and one to ground.
I don't know what colour codes Ibanez use - they seem to vary a lot - but if it does have two wires connected to the switch, the Red from the BKP should connect to one of those points, the Green+White should connect to the other.
« Reply #4 on: August 19, 2010, 09:34:09 AM »
The pickup wire colours will be different, but you should be able to work it out from this wiring diagram and this colour decoder:
* Red on BKP and Red on Ibanez 'bucker go to the same place
* Bare and blue on the Ibanez swap to bare and black on the BKP
* Black and white on the Ibanez 'bucker are replaced by green and white on the BKP
http://www.guitarelectronics.com/category/wiring_resources_guitar_wiring_diagrams.humbucker_wiring_color_codes/
« Last Edit: August 19, 2010, 09:37:51 AM by Twinfan »
