Author Topic: JCM800 Problem  (Read 4390 times)
TomW
    • http://www.myspace.com/wolfiosg
JCM800 Problem
« on: August 18, 2010, 10:18:14 PM »
Hi guys,
The high input on my jcm800 4104 seems to have stopped working. Has anyone got any ideas of what could have caused this? The low input still seems to be working fine. I also just changed the preamp valve in the V1 position, but I don't see how that could have caused the high input to stop working.
Any ideas?
Riff Raff/Stormy Monday, Holydiver and Mississippi Queen!!!
www.myspace.com/therealamorist
Re: JCM800 Problem
« Reply #1 on: August 18, 2010, 10:25:44 PM »
Broken input jack or solder joint?  Should be a cheap and easy fix?
Can you put the old valve back in to check?
Re: JCM800 Problem
« Reply #2 on: August 18, 2010, 10:59:23 PM »
i haven't looked at the circuit in a while, but i seem to recall the high input has an extra gain stage from V1. A dodgy valve could cause this. twinfan makes good suggestions, also look at the valve holder.
martinw
  • Building Amps in the Hills.
    • http://www.mjwamps.com
Re: JCM800 Problem
« Reply #3 on: August 19, 2010, 10:06:34 AM »
The High signal on those doubles back through the switched part of the Low input jack. As hardly anyone ever uses the Low jack, the contacts of that switched part get dirty and break down. Try using some contact cleaner and inserting a jack plug a few times in the Low input.
If not, and a new valve doesn't fix it, you'll need to have a look inside and break out a meter.  :)
Custom Built Amps:
www.mjwamps.com
TomW
Re: JCM800 Problem
« Reply #4 on: August 19, 2010, 11:14:50 AM »
Cheers for the suggestions. I'll have a go at them later today and see what happens. Thanks
