Modding an Epi Black Beauty
Started by Veracity, August 30, 2010, 05:14:52 AM
Veracity
I just bought a used Epiphone Les Paul Black Beauty 3 (2006). The former owner replaced the pickups on it with Dimarzios: a Drop Sonic in the bridge, a PAF PRO in the middle and an Evolution in the neck.
I have never played on anything but cheap stock pickups before. But these upgrades don't suit my tastes at all.
I want to replace them with Bare Knuckles pickups. And I would like to use the three pickup slots to produce a good variety of distinct tones. Specifically, I want something glassy and chimy in the neck for clean blues and jazz, something warm but not muddy in the middle for chords, Southern Rock and slide, and something British classic rock in the bridge.
I listened to a ton of sound files and these are my initial choices. I was thinking of putting a Mule in the neck, a Mississippi Queen PAF in the middle and a Black Dog in the bridge. I don't want matched sets. I want a distinct variety sounds.
Does this sound like a good combination for someone who likes to play Blues, Southern Rock and British Rock? I listen to a lot of Allman Brothers, Led Zeppelin, Derek Trucks and Black Crowes, if that helps.  Those are the sounds I admire and would like to capture.
Also, I would love to mod this Black Beauty to take advantage of the possibilities three pickups provide. I would like to be able to play the pickups in and out of phase, single coil and humbucking, with about 7 pickup combinations. Where can I learn how to set up the wiring/hardware for that? What kind of advanced hardware would I need?
Thanks a lot in advance!
Transcend
i arent sure on the sounds that you are after but i believe for the wiring options your best bet would be push/pull and rotary pots wiring it up i have no idea about though.
This part of your question would be best asked in the tech section after you have focused in on the ideal pickups
Deadstar
Hey, welcome to the forum.
I did something similar with my black beauty (pic below) Your pickup choice seem suitable enough for the sound you're going for. Definitely recommend the MQ in the middle that's what I've got on mine - is nice thick and full but retains a chimey-ness to the top end which brings out the clarity.
I wired mine (three P90s) with the all access style wiring like on a Yamaha TVL, allows a full range of tones from very clean to very dirty. Works in the way that you can have the traditional les paul switching or bring in the middle either on its own or with either or both other pickups providing 7 options. Word of warning - switchcraft switches are a little wider than the stock hardware as are cts pots so if you're changing them too then a little work if required, nothing complex just needs a large wood drill-bit to let them fit properly.
If you want coil tapping/polarity switching then push-pull is the way to go as it doesn't change the appearance of the guitar at all.
"The secret to creativity is knowing how to hide your sources." -Einstein
