Author Topic: graph tech saddles  (Read 4066 times)
Ochaye
graph tech saddles
« on: September 09, 2010, 04:23:20 PM »
the string savers.......any you guys changed out yer les paul saddles with these things?
are the nothches ok on the saddles? is it a straightforward swap over?
Deadstar
Re: graph tech saddles
« Reply #1 on: September 09, 2010, 05:25:21 PM »
Yeah, I put in one of the resomax bridges on my epi lp. It's straightforward, though it might be a tighter fit it's easy enough to get in by hitting it down lightly with a rubber mallet or use the end of a screwdriver protecting the bridge with a cloth so you don't damage the finish.
Just make sure you get the right size, they supply both metric and imperial sizes depending on what type of guitar you've got. (eg - USA or Korean.)
If your getting the nut with it that might be a little more complicated, it's not that hard but if you fear damaging your instrument it's best to play it safe - if your in any doubt go to your local tech.
"The secret to creativity is knowing how to hide your sources." -Einstein
