Custom built Footswitches in the UK?
Started by Brow, September 13, 2010, 12:38:08 PM
Brow
Hey guys.
After a days jamming with my new Splawn Quick Rod I've decided that (for the forseeable future atleast) I'm going to forego my G-Major in the loop and just use the amps gain sounds and a wah.
I want to use a 4 switch footswitch so that I can have control over Clean/OD, OD1/OD2, Solo Level on/off and Low Gear/High Gear (you can't normally change gears using the Splawn footswitch) but as the amp runs off 2 stereo 1/4" jacks (ring and tip on each) for footswitching, I'm thinking I may need to have something made up.
Does anyone know of anywhere in the UK that may be able to do what I'm looking for?
Thanks.
Craig
EDIT: In the original posting of this people suggested/recommended Martin at MJW Amps, Flynn amps and JuanSolo
out of interest how do you normally change gears?
EDIT: Answered that myself.
blue
another one is monkeyfx.  he'll put together pretty much anything you want
Pete24v
+1 for Andi @ MonkeyFX, build 2 switch boxes for me. I recall something about him taking time off though..
Brow
Monkey FX was the 1st I thought of apart from Red Onion, but Red Onion appears to have disappeared altogether and Monkey FX is no longer building  :?
As I said in the (deleted) thread from Sunday, I had a MonkeyFX fuzz/boost pedal that was a pile of junk, so I couldn't recommend them.
