Author Topic: MQ or Manhattan..for a 335 /jack white sound  (Read 4923 times)
tomm
« on: September 28, 2010, 09:01:45 PM »
Hi everybody,
i'm thinking about getting an holowbody guitar..i want a gibson 335,but because i'm a starving studend i thought that i can buy an epiphone dot or a sheraton II and change what i can. So, i'm looking for a resonate twangy,but not airy,clean sound and a raw crunchy tone for dirty ( i use a fuzz 99% of the time so i want a pick up that work well with it)Can the Mississipi queen or the Manhattan give me this type of sound?
cheers
http://www.youtube.com/watch?v=5Am5J_cid7w
http://www.youtube.com/watch?v=K3MJru1tfZQ
Fourth Feline
Re: MQ or Manhattan..for a 335 /jack white sound
« Reply #1 on: September 28, 2010, 10:29:06 PM »
Hiya Tomm,
I would say the M.Qs ( with subtle adjustments to pickup height to get the best balance between the two sonic examples you cited )  would be good for those sounds.
I had mine in a 335 copy, and whilst I don't play those styles of music, I feel that could have covered those two tones you posted quite easily.  Set the M.Qs  closer to the strings for a thicker, fatter 'chewy' sound - and a bit further away for twang, bite and snap - ( see also the other very recent M.Q thread for our supporting comments and such ).
The Manhattan is a no-no for your needs, as it is wonderfully, open and airy ( detailed , yet rich and warm Jazz Chord melody heaven basically ). As I once remarked on a thread some while ago , M.Qs give you detail and clarity on the edge of the notes, whereas the Manhattans give you warm articulation on the spaces / details in between.
  My vote , therefore would be for M.Qs .  :)
« Last Edit: September 28, 2010, 10:34:42 PM by Fourth Feline »
5F6-A
« Reply #2 on: September 29, 2010, 09:49:03 AM »
Interesting combo that you are after.... the manhattan is clearly a Jazzy sounding pickup but then again Les Paul & Seth Lover thought of the Les Paul design to be a country / jazz guitar and NOT a rock and roll monster. :)
"I now consider atheism to be brutal because it offers neither consolation nor liberty of any kind" Benjamin Constant in 1804
"Practice until you can hear the metronome grooving" Carol Kaye
tomm
« Reply #3 on: September 29, 2010, 01:14:39 PM »
thanks guys..so is a M.Q the right choice?i'm only afraid about that maybe the m.q is  too round and warm  for that "snap and twang"sound,but maybe i'm wrong
Fourth Feline
« Reply #4 on: September 30, 2010, 08:58:33 AM »
Hello again Tomm,
having given further consideration to that last question, perhaps you might be better to consider the fitting of a pair of crisp Riff-Raffs ;  as they would be closer to the 'historically accurate' sound of an early 335 - and you can always ( as Larry Carlton does a lot ) - play on the bridge pickup with the tone control on the guitar turned far down, to replicate 'fatter' sounds.  You will therefore also have the benefits of a fully hum-bucking pickup at higher gain settings as well of course .   However, I still like the M.Q idea - as a P90 / P91 / P92 type pickup does sound wonderfully unique.   As always , if in doubt, consult Tim at B.K.P .of course.  :)
« Last Edit: September 30, 2010, 09:04:11 AM by Fourth Feline »
« Reply #5 on: September 30, 2010, 11:34:08 AM »
Based on clips and description, I'd say Riff raffs too.
tomm
« Reply #6 on: October 01, 2010, 02:35:29 PM »
Really? I know that jack white uses  single coil under the humbuckers cover,and the tone of the early 335 sounds very open like a sort of resonate telecaster,isn.t it?and i'm afraid about  the fuzz-humbucker combination( dont' want a muffled compressed sound)
James137
« Reply #7 on: October 07, 2010, 10:09:22 AM »
I have MQ's in my es137 and they are very versatile pickups. The bridge pup does Jack White perfectly (his Airline guitar as in this vid which has humbucker sized single coils) with a big muff you'd be right there
http://www.youtube.com/watch?v=03YUgHAshSo
Not the only trick to these pups though. As said they are awsome versatile pickups.
« Last Edit: October 07, 2010, 11:12:12 AM by James137 »
« Reply #8 on: October 07, 2010, 12:19:37 PM »
just fyi, Tonequest did a great article on Airline guitars (like Jack White uses in that youtube video you posted)...  http://www.eastwoodguitars.com/pdfs/TQRFeb06.pdf
To be honest, I think the fact you're using a different guitar to Jack White will dictate a slightly different approach in choosing the right pickup.  When you add fuzz into the equation as your main effect, its got to be single coil pickups imo, so MQ would be my choice - humbuckers just fart out with fuzz (imo).
Good luck with a 335 and a fuzz box too - thats a recipe for howling, uncontrollable feedback if I ever heard one, it'll be a tough ride to keep under control  :D
tomm
« Reply #9 on: October 09, 2010, 11:02:34 AM »
yeah..but i hope that an orange amp plus an hollow guitar and a fuzz box do the trick...maybe i need a noise suppressor :lol:
James137
« Reply #10 on: October 09, 2010, 09:46:50 PM »
You should be alright really. It's not asif your playing a full hollow body guitar. Don't know about the orange amp but ive got a Laney vc 15 and that works pretty well for the jack white tone. Im sure that with a fuzz pedal and a whammy it would be spot on the same.
Spiteface
« Reply #11 on: October 10, 2010, 12:57:16 PM »
Yeah, I have an Epiphone Dot with Riff Raffs, and it just sounds fine through my Tiny Terror with a Big Muff.
Proud owner of a set of Riff Raffs and Emeralds.
