Author Topic: PG Blues installation and wiring  (Read 5511 times)
ic
« on: September 30, 2010, 08:11:07 AM »
Just a few quick Q's about installing my new pups;
- should I install the neck pup 'upside down' i.e. so the screw holes are towards, and matching the bridge pup? (I suppose what I'm really asking is, does having the same orientation aid the phase cancellation effect in the middle position?)
- I imagine PG's guitar had 50's style wiring, but was it wired for 'independent' volume controls? (i.e. with pup and switch wires reversed at the volume pot?) The instructions that came with the pups show a 'modern' style wiring.
I know I should probably experiment and see what I like best, but I was after a starting point that was fairly authentic.
TIA, Ian.
Re: PG Blues installation and wiring
« Reply #1 on: September 30, 2010, 01:40:41 PM »
Instal the neck with the screws away from the neck (same as PG guitar) is the way Tim shows it, however as it is not a magnetic out of phase, but is electric, I think this isn't really necessary.  The wiring is changed in the pickup, so the pots are wired normally.
« Reply #2 on: October 07, 2010, 05:44:22 PM »
Sometimes even GAry had the pickup the right way round too!
Made no difference to the sound as the pickup was electrically out of phase, although some people say there is a slight difference having the slugs nearer the neck rather than the screws when using the neck pickup
See below
http://www.youtube.com/watch?v=Q2nVyHmHaSQ
Ribboz
« Reply #3 on: October 09, 2010, 04:49:38 PM »
Nice vid Feline  PDT_003
C-pig, C-Diver, Holydiver, Miracle man, Sinner, Trilogy, Slowhand.
