Miracle Man vs Ceramic Warpig vs Ceramic Nailbomb.
Started by jonathanf, October 10, 2010, 08:46:39 AM
jonathanf
Hello.
What 6-string guitar pickup would you recommend to suit my style. My guitar is an H/S/S alder body, maple neck, rosewood fretboard. I only want a humbucker, I play metalcore tuned to drop B and drop C(Parkway Drive, Killswitch Engage), so I need it to be very tight but not necessarily a ceramic magnet, I also play  thrash metal(Metallica, Slayer) so It needs to sound just as good in E and I also play modern metal(All That Remains, As I Lay Dying, Trivium). I want to get the best sound possible but also not totally different from the bands sounds(but its not a big problem since I have a Pod X3, I play through headphones only but will be getting some studio monitors in a few months). Which pickup do you think would sound the best for my style but can also get quite close to bands sounds? I think I'll look in to a Miracle Man, Ceramic Warpig, alnico warpig or ceramic nailbomb. Do the pickups come with all the pots needed?
Thanks.
I'd pick the miracle man for pretty much all the bands you listed
any of BKP ceramic models will work, though
jonathanf
Thanks, so it comes with all the pots needed right?
jonathanf
Are there any diagrams, tutorials to install these pickups(being H/S/S, will it be different).
Chris Rowberry
Hi
If you buy it as a pre-wired gaurd then all pots will be included but if you wish to install them yourself you can buy pots off BKP too.
As for diagrams if you order online just request one in the comments box or if you order by phone ask the person talking to you.
Here to help!
chris@bareknucklepickups.co.uk
jonathanf
Sorry for all the questions. Do BKP's run on 500k pots? I'll look on the website.
jonathanf
Will I just need to get new pots(mine are 250k, I think)or do i need to other stuff, I mean I've got a 5-way switch, tone and volume knob and an input jack, so anything else? I guess the installation is gonna be really annoying.
dheim
they all sounds good in E as well as in lower tunings... the only one able to sound downtuned even in E is the Pig, anyway! for me the MM is the less aggressive of the bunch, but Eric will argue for sure! :)
too many? ;)
jonathanf
Thanks, I'm pretty sure I'll get the miracle man but its all this installation thats the problem, I've read that you need to replace nearly all the electronics in the guitar, but I'm pretty sure only the pots need changing, my guitar is routed with passives, except the pots are 250k.
jonathanf
Also, do you think I should pay for installation or do it myself. I mean, you just need to follow the instructions. :?
Is the guitar already HSS? And you're replacing just an existing bridge humbucker?
If it works as is at the moment, you've already got pots/etc that will do a job, if not the job.
In that case, in your situation, I'd probably leave the wiring/pots as is at first and see what happens. If you do it that way, the wiring/soldering is not too difficult. Go slowly and methodically (only undo the wires that need undoing to take the old pickup out, make a note of where they went, etc).
If you're new to soldering, maybe practice a bit first, and get ready for burnt fingers! I learnt to solder inside guitars and never damaged anything. I tell a lie - make sure you protect the finish with old towels or something! You learn that pretty quickly - hot solder and soldering irons go through guitar finishes very easily, burnt fingers heal quite quickly, guitar finishes don't :lol:
I reckon you could do it, and you'll feel better for it. And, in the long run, learning to do this sort of thing yourself is loads cheaper. But, if you do decide to take it to someone, there's no shame in that either :D (the best would be if you know someone who knows about this stuff, and they're willing to do it while you watch).
Welcome to the forum :D
Quote from: dheim on October 10, 2010, 03:14:40 PMfor me the MM is the less aggressive of the bunch, but Eric will argue for sure! :)
not gonna argue with that, but it's still the closest to those band tones
