Author Topic: BKPS for an Edwards LP  (Read 1700 times)
sandmannn69
« on: October 21, 2010, 04:28:37 AM »
I've got an Edwards Les Paul Custom (Sykes model) that I'd like to put some BKPs in, as the Duncan Distortions are too darn thin and harsh, especially since I put a Miracle Man set in my Charvel SoCal. Cold Sweats would be an obvious choice, I suppose. This Edwards is much lighter than a Gibson, probably due to the Asian mahogany used in the body and neck, and appears to be brighter-sounding, too. Probably going to test it with the MM set from the Socal, as I've read a few rave reviews on HC about folks putting MMs in Gibson LPs. If anybody has gone with a ceramic BKP on their Edwards LP, like to hear your input/opinions....
Charvel San Dimas/VHII
Charvel Tele/HD set
Dean Z MM/set
Gibson LP
Kramer 5150
Jackson Soloist
Re: BKPS for an Edwards LP
« Reply #1 on: October 21, 2010, 06:49:25 PM »
I just moved a cold sweat set into my '73 lp custom and it was a big improvement over a motor city set and the nailbomb set it had before
I was avoiding that combination cause I didn't want to follow the obvious Sykes path for my main guitar, but I had that set in a les paul copy for years
but my '73 is quite dark and focused
very dense sounding
you should try the miracle man first, imo
sandmannn69
« Reply #2 on: October 21, 2010, 10:35:11 PM »
very dense sounding
Eric thanks for the info. Guess I'll try the MM set. The bridge is F-spaced but should be able to get a general idea how they sound in the Edwards.
Charvel Tele/HD set
Dean Z MM/set
Gibson LP
Kramer 5150
Jackson Soloist
« Reply #3 on: October 21, 2010, 11:33:10 PM »
did you measure the string spacing of the edwards?
gotoh bridges are f-spaced
sandmannn69
« Reply #4 on: October 22, 2010, 05:39:51 AM »
Edwards is 50mm (not F-spaced)
Charvel Tele/HD set
Dean Z MM/set
Gibson LP
Kramer 5150
Jackson Soloist
