Author Topic: VHII Single Coils...?  (Read 3675 times)
Bainzy
    • http://www.shredaholic.com
« on: December 18, 2005, 11:34:02 PM »
So I finally got round to fitting a miniswitch in my custom guitar with calibrated VHII's for coil tapping earlier today. Took a while to sort out the wires and test it as it's getting a bit crowded now with a miniswitch AND a midboost kit.
First impressions - wow! The switch when activated only turns on the outer coils (screw coils) of the humbuckers the way I've wired it, as I was going for more strat like sounds - and in that aspect it really delivered. I tested the single coil mode against the 2004 USA Fender Strat I've got with stock pickups, and I think I like the tapped sound on my custom guitar more! On clean with a bit of chorus on the amp, the sound was beautiful - complex and shimmering.
The pickups sounded very close to strat pickups partly because of the coils that I chose to tap, but also because of the layout of them. The custom has a neck pickup placed with the screw coil where the strat neck pickup would be (nothing new there), but also the bridge pickup is at the same angle as a strat's bridge pickup. With the 500k pots I used the bridge single coil mode sounds just a little ice pickey, but turning down the volume very slightly (8 at the lowest) doesn't really roll much volume off but takes a bit of high end from the sound, which just nicely kills that slight 'ice pickey' sound.
I'd really recommend doing a switch like this with a pair of VHII's (mine was a miniswitch but you could probably use a DPDT on/on push-pull control pot instead, so the guitar looks the same cosmetically). These VHII's are just an incredible pair of pickups - they're perfect distorted rock pickups for me, but I've never been a fan of any humbucker's clean sound so before now I wouldn't have used them for that. Now I've discovered how tapping them gives such a great clean sound, the guitar has become so much more versatile.
I've been putting off filling in a HC review and Shredaholic.com review until I could review the pickups tapped as I didn't feel the review would be comprehensive enough, but now all I need is to get a pic of them in my guitar and I'll get the full review up.
shredaholic_nicz
« Reply #1 on: December 18, 2005, 11:55:56 PM »
cool youll have to let us hear next time we jam
http://www.shredaholic.com - for all your shred guitar needs.
« Reply #2 on: December 18, 2005, 11:57:20 PM »
Great review! Thanx for that.
The switch on my VHII is to roll off the high freqs from the hard ash guitar body. Down is a little bit of roll off, Up is a bit more Gibson kinda sound.
willo
« Reply #3 on: December 20, 2005, 03:39:49 PM »
I have coil tapping on my VHIIs with push/pull pots, I got that done on the advice of jt, and have never looked back. I'm not sure which coil exactly it uses from the humbucker, but try tapping the neck pickup, keeping the bridge as a 'full' humbucker, pickup selector at middle position, through a boost pedal into a plexi style amp. I loved that tone!
Bainzy
« Reply #4 on: December 20, 2005, 10:27:21 PM »
Quote from: TwilightOdyssey
yeah I put down the very slight ice pickey sound partly due to the body wood aswell, since it's also a hard ash body
Bainzy
« Reply #5 on: December 20, 2005, 10:27:50 PM »
Quote from: shredaholic_nicz
will do!
