Author Topic: My amp has now died.. TSL 601  (Read 14625 times)
Transcend
« on: October 28, 2010, 06:44:34 PM »
It was working absolutely fine the last time i used it.
It powers up but the valves do not heat up at all.
My first thing was to check the fuses both are fine
i then replaced all the valves and alas still no heat to them.
Does anybody have any idea what it could be and how much work it is to fix it.
I'm obviously not going to go inside the amp myself but is it going to be a lot of work and a pricey fix?
I have been toying with the idea of getting a JVM for a month or so now so i may just sell this on as spares or repairs and get the JVM if its going to be an expensive job.
Thanks
Keven
Re: My amp has now died.. TSL 601
« Reply #1 on: October 28, 2010, 09:34:02 PM »
I'm no expert but maybe the transformer supplying the heater voltage has died? or the diode bridge converting the 9v ish ac to 6.3v DC died. have a tech look there first? i know that's where i would go next if the valves were new and i still got no heater current.
My BK's:
C-Bomb Set / Blackhawk Bridge
Holydiver Set/ BG50 Set
« Reply #2 on: October 28, 2010, 10:24:18 PM »
there might be no diode. a standard heater arrangement (i guess most common anyway) is an additional winding on the power transformer at about 6.3v AC rated for enough current given the valve arrangement. that will be two wires, and you might have a centre tap attached to ground. or a 'faux' centre tap which is a resistor on each wire meeting at a ground point. you might even have a pot. like a fender heater hum balance pot.
if you have DC heat anywhere, or anything fancy associated with that like diode and capacitors and regulators then you could have a problem there.
It should be a very simple circuit compared to the rest of the amp though. It also shouldn't have that many parts to go wrong unless marshall do something wild with it. repair costs might be a bit because you'll probably have to dismantle the amp to get to the underside of the PCB to swap any parts on it.
EDIT.
I had a look at the TSL100 schematic, it has DC heater on v1 and v2. the power valves and v3 v4 are AC heated.
The AC part has a faux centre tap. The DC is fed in series from the end of that chain of AC filaments (if you will). It does have a bridge rectifier and some diodes in place for that. But if that BR failed I might be inclined to think you'd loose heat to only 2 valves. rather than all of them...
...maybe someone can enlighten me.
http://www.drtube.com/schematics/marshall/tl10-60-02.pdf
« Last Edit: October 28, 2010, 10:34:35 PM by Dmoney »
Transcend
« Reply #3 on: October 29, 2010, 06:22:55 AM »
Thanks guys for all your help. It's been much more helpful than the marshall forum which was pretty much oh well its a cr@p amp buy a better one.
I have the combo version which is just 4 12ax7 and 2 el34. I am getting no heat to any of them at all.
I'll get James healey to have a quick look at it this weekend as he's up anyway now that i have more of an idea what it could be.
If anyone can spot it he should be able to with him building amps himself.
Thanks
Pete24v
« Reply #4 on: October 29, 2010, 08:36:37 AM »
i had one of these with the same problem. It was a a blown internal fuse, something to do with the valve heaters. It went a few times, my local tech then did a mod which stopped it happening again
« Reply #5 on: October 29, 2010, 08:48:29 AM »
I hope the mod wasn't along the lines of swapping the fuse for some scrunched up tin foil... lol
Frank
« Reply #6 on: October 30, 2010, 01:42:42 PM »
It's quite rare to see an amp with fuses in the heater circuit, especially one fuse per tube as in that schematic. Don't really see the point of it, what's the point in cutting off the heater supply and leaving the HT supply on to the tube? And I'm surprised they're specified as 6.3 Amp when EL34s are rated at 1.5 Amp for the heater - if it's blowing a 6.3 Amp slo-blow fuse then something very weird is happening in that tube, maybe one of the resident amp gurus can shed a little light on this?
« Reply #7 on: October 30, 2010, 02:02:27 PM »
oh yeah!
how odd. can't believe i didn't notice that. although it isn't really something i would have thought to look for.
only thing i can think of is it protect against some kind of short in the filament. The will be drawing over 6.3A in total, but a fuse on each EL34 is new to me.
still. there are 4 fuses. you'd need a combination of fuses going to take out all the heaters right?
I can't spot one fuse that would kill them all.
Transcend
« Reply #8 on: October 30, 2010, 04:50:21 PM »
I'm absolutely lost in all of this. I'll post an update tomorrow after James' has had a look at it and if he can't sort it after i find a tech that will actually touch it.
The Marshall service centre said they no longer service TSL/DSL's yet they said replacing the main board would probably fix any issue and i could order one through a marshall dealer :S
« Reply #9 on: October 30, 2010, 05:06:36 PM »
can the OP take one of those fuses out the amp and confirm their rating - no way it could be 6.3A, even the mains fuse is only 2A.
Transcend
« Reply #10 on: October 30, 2010, 05:11:22 PM »
ill find out for you tomorrow when James is hear i dont want to mess around with it internally not knowing anything about them
Frank
« Reply #11 on: October 31, 2010, 01:24:16 AM »
Looking at the schematic, all 4 fuses would have to blow for the all 4 EL34 heaters and the ECC83 heaters to stop working. So maybe there's a serious short in the heaters? Or the power transformer has packed in?
The neon light coming on means ... not a lot. If it's connected across the PT primary (not checked this on schematic) then all that means is there's mains voltage coming into the amp from the wall socket, I'd check the schematic then ignore that completely.
please tell me he didn't just push a steel nail into the fuse holder? WARNING - DO NOT DO THIS!
« Last Edit: October 31, 2010, 01:27:29 AM by Frank »
Frank
« Reply #12 on: October 31, 2010, 01:32:52 AM »
Yes it can!
The 2A is the 240V supply, if it's stepped down to 6.3V then 6A is no problem. The EL34 heaters would add up to 6A for 4 tubes.
Transcend
« Reply #13 on: October 31, 2010, 08:20:48 AM »
Well mine is the combo version that only has the 2 power tubes.
Where are you guys getting these shchematics from?
The general consensus from the Marshall forum is the same as here
that its the 6.3a fuse but that its caused by a diode shorting due to heat and it being undersized for the job
« Reply #14 on: October 31, 2010, 08:50:02 AM »
there are a few places you can find them
you just have to google it. I couldn't find a specific 601 schem but i found teh TSL100 and it probably translates quite well.
The BR is only supplying the first 2 preamp valves with filament voltage. I know with usual AC heat a whole 12AX7 draws 300mA. I'm not sure if that changes for DC heat. I think it just about doubles current consumption (correct me if im misinformed). Which would give you ~1.2A draw from V1 & V2. If that diode if the problem then there are probably loads you could fit in its place which are higher spec depending on PCB.
