November 21, 2026, 12:08:17 AM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Guitars, Amps and Effects
Putting a patch cable across the effects send/return as a boost?
Started by Transcend, November 03, 2010, 04:03:34 PM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
Transcend
Guest
Logged
I just had the thought of putting a patch cable across the loop sockets and pressing the +10dB button and thought this may work as a 10dB boost.
Is there any risk of this damaging the amp?
and will it work i dont wanna just try it as ive recently had a few problems with it.
Light Heavyweight
Logged
Re: Putting a patch cable across the effects send/return as a boost?
#1
November 03, 2010, 05:34:24 PM
Should be OK - people use EQs and boosters in loops. You're just hammering the powervalves a bit harder...
Middleweight
Logged
#2
November 03, 2010, 05:52:15 PM
Well if you run a true bypass effect in the +10dB setting it's basically the same. So no, no issue with this, as long as it sounds good 8)
Transcend
Guest
Logged
#3
November 03, 2010, 06:37:28 PM
it sounds pretty good on the crunch channel but on the lead it takes things a little too far for my liking.
thanks guys
Print
Go Up
Pages
1
User actions
Forum Ringside
User actions
Print
