Author Topic: BKP Mule Neck Overdriven clip  (Read 5942 times)
Ronnie Robinson
« on: November 06, 2010, 11:49:21 AM »
Solo is a BKP Mule (neck pickup) and overdriven chords played using my BKP Mule (bridge pickup) both fitted to my PRS McCarty played through a Blackstar valve Amp and recorded via a Tascam interface. No effects except overdrive which was provided by the Amp.
Cheers
« Last Edit: November 06, 2010, 12:08:38 PM by Ronnie Robinson »
PRS McCarty (BKP Mule set)
Fender USA Strat deluxe (Irish Tours)
Gibson Sg Standard
gordiji
Re: BKP Mule Neck Overdriven clip
« Reply #1 on: November 06, 2010, 12:21:40 PM »
sounds great ronnie, both the ryhthym and lead, how a guitar 'should' sound 8)
Ronnie Robinson
« Reply #2 on: November 06, 2010, 12:32:09 PM »
Cheers, unfortunately I seem to be having a bit of a technical problem as the uploaded version on the forum is very quiet -, I've increased  the volume on the recording but still crash and burned when it comes to the uploaded version  - oh well practise makes perfect ....... .
« Last Edit: November 06, 2010, 12:44:15 PM by Ronnie Robinson »
Gibson Sg Standard
broknstrngz
« Reply #3 on: November 09, 2010, 06:08:18 PM »
Yeah, the forum is Hard To Handle :)
The solo isn't loud and clear enough, and it's panned right too much. Did you cut some of the highs?
Ronnie Robinson
« Reply #4 on: November 09, 2010, 07:44:08 PM »
Thanks for your reply although I have to say the mix sounds about right to me ... Cut some highs ? A little on the guitar but mainly its the tone of the neck pickup - thats what it sounds like.
Gibson Sg Standard
broknstrngz
« Reply #5 on: November 09, 2010, 09:18:52 PM »
It depends on the system used for mixing. I've just given it another listen through my laptop speakers and it sounds good indeed. I previously listened through my headphones, which is weird, because they are usually too bright.
Thanks for the recording, mate ;) What gear did you use?
Ronnie Robinson
« Reply #6 on: November 10, 2010, 05:59:31 PM »
Yep sure the type of speakers makes a big difference. It was recorded using a tascam interface and Cubebase recording softwear
Gibson Sg Standard
