Author Topic: how would i adjust this diagram for a coil split/tap  (Read 4130 times)
Transcend
« on: November 09, 2010, 05:46:33 PM »
Ive attached the wiring diagram for the standard ibanez wiring but i want position 4 to just be a coil split/tap (not sure of the correct term)
as i dont want to have to get my magnet reversed in my neck pickup as it is in the original ibanez neck pup.
thanks guys
juansolo
    • Juansolo's Gnomepage
Re: how would i adjust this diagram for a coil split/tap
« Reply #1 on: November 10, 2010, 08:11:31 AM »
If you're wanting to split the neck HB that's going to be awkward to do if you want to also keep the serial/parallel switching on it also. You'd probably only be able to do it with a fender super switch which will allow you to do pretty much any combination of wiring you can think of.
Transcend
« Reply #2 on: November 10, 2010, 03:51:16 PM »
Its just the bridge humbucker that im wanting to be split alone i dont want it to also have the slug coil of the neck pickup on that switching option
juansolo
« Reply #3 on: November 10, 2010, 05:46:04 PM »
Without getting my hands on it, I don't know what that switch is doing where. Sorry about that :( It does sound like it might be possible. I still stand by that if you can get a super switch in there, you can wire the 5 positions to do whatever you like. They're wonderful things.
Transcend
« Reply #4 on: November 10, 2010, 06:36:55 PM »
Ill look up this superswitch thanks for your help.
