Author Topic: Pickup for alder body, maple neck, rosewood board.  (Read 2611 times)
TheImmaterial
« on: November 11, 2010, 11:55:37 AM »
Hi, I've decided to resurrect my very first guitar with some bareknuckle TLC. It's bascially a pacifica model but with a humbucker at the bridge (H-S-H). It's gonna be a back up/workhorse/no nonsense affair so the plan is to get a nice tight, punchy bridge pickup mainly for modern punk rock distortion powerchords/riffs (preferably no scooped mids). I'm going to wire it straight to the output so I don't have to worry about pots and caps :)
I'll be running it through a randall or mes boogie rec to give you an idea of the distortion i use. Any advice would be appreciated.
Nolly
  • Global Moderator
Re: Pickup for alder body, maple neck, rosewood board.
« Reply #1 on: November 11, 2010, 12:28:08 PM »
Hey
I think the Nailbomb would work rather well for that  :)
TheImmaterial
« Reply #2 on: November 11, 2010, 01:05:22 PM »
Cool, thanks. Do you know if i'll need the 50mm or the 53mm? Here's a link to the guitar if it's any help.
http://usa.yamaha.com/products/musical-instruments/guitars-basses/el-guitars/rgx121s/?mode=model
aik
« Reply #3 on: November 11, 2010, 03:01:55 PM »
For Tremolos usually 53mm is the right spacing. Best way to make sure is to simply measure the space between both E strings.
