Author Topic: Which pots and caps  (Read 6591 times)
6string
Which pots and caps
« on: November 18, 2010, 05:51:34 PM »
I'm building a strat with a crawler and 2 mothers milks.  Which pots and caps would everyone recommend?
BigB
  • Let's rock !
Re: Which pots and caps
« Reply #1 on: November 18, 2010, 07:35:33 PM »
Never had an HSS guitar but IIRC the canonical solution is to use 250K pots and add a 250k resistor serial between the bucker and the volume pot. wrt/ tone caps, you'll probably want to wire it with both SC sharing a same cap and pot and the bridge using the second pot with a distinct cap (you should find the appropriate wiring diagram on http://guitarnuts.com). If so get a 500K pot for the bridge tone.
My 2 cents (before someone way more knowledgeable chimes in...)
