Author Topic: Direction of Humbuckers  (Read 8605 times)
DvE
« on: November 20, 2010, 11:35:58 AM »
Hi all,
I am currently trying to install my new set of aftermath pus.
Since they have screws on both sides from underneath, I dont know the orientation.
Any help in which way I should install them? Does it make a difference?
Thanks for you help.
Nolly
  • Global Moderator
Re: Direction of Humbuckers
« Reply #1 on: November 20, 2010, 04:56:44 PM »
The bridge pickup should have the cable leaving from the bottom left as you look at the back of the pickup, the neck cable will exit the pickup from the top right. The bridge Aftermath actually features a symmetrical wind so it in fact could go in either way, not sure if the neck model is symmetrical too though.
Enjoy your pickups! :)
Bhaal
« Reply #2 on: November 23, 2010, 11:15:02 PM »
http://bareknucklepickups.co.uk/forum/index.php?topic=22574.msg300681#msg300681
Quote
Bridge DC14.7K ceramic, neck DC11.5K Alnico - these are symmetrically wound...
Seems like you can really install 'em both in any direction.
« Reply #3 on: November 24, 2010, 12:12:57 AM »
with symmetrically wound screw/slug pickups you can hear a difference - not as much as i was hoping though
DvE
« Reply #4 on: November 24, 2010, 12:30:26 AM »
Ok, I installed the bridge pu in the way the cable fits better, but I am not shure, if I put the neck in the right direction.
Can I use the small holes on the top as orientation? (They are only at one side of the humbucker)
Transcend
« Reply #5 on: November 24, 2010, 06:18:42 AM »
what i basically do is fit it so the wire is coming out at the same place as the pickup cavity is drilled for the wire to leave through.
Always made sense for me to do things this way as it always seems to be the bottom left which always matches up with the pickups
« Reply #6 on: November 24, 2010, 03:11:33 PM »
That's what I did, but I don't have a neck pickup so can't comment on that one. But as others have said, they're symmetrically wound, so it *shouldn't* make a difference!
Roo
