polishing up a satin finish guitar
Started by Dmoney, November 22, 2010, 12:15:50 AM
so.
is there a good way, some easy steps, to go about buffing up say... a faded gibson SG finish into a glossy finish?
what polish/tools/method would be needed etc?
cheers!
Some sort of car polish and a soft cloth should do the trick?
Best to do it by hand than use tools which may eat through the thin finish...
I'm occasionally using Briwax on mine (maybe once every 3 or 4 months if I remember or feel like it).
If it is a Gibson faded, make sure you use a darker Briwax. I have two tins of it, the lighter of which which I used to use on bare maple necks. I used this on the SG once and I was left with annoying paler wax residue in the grain. Can't see it from a distance, but it's annoying anyway.
I got a darker tin to finish the Explorer I stripped, and when I used this on the SG it fixed the earlier problems. Coming along nicely now. I wouldn't say it's going to get me to a "glossy" finish, but it is developing a nice glow.(Incidentally, I use the darker one on maple necks as well now...)
And I'd definitely do it by hand - the original colour on mine is already wearing off the back of the neck from just playing it on and off for a year...
Cheers for the help guys.
I'll get some pics of the guitar i want to work on put up later (NGD!)
I'm apprehensive about getting stuck in until i'm sure i have a good understanding of what to do, from what to use for what exactly, right down to just how hard i need to rub!
T-cut will do the trick, but bear in mind that the matt finishes on things like Gibson Fadeds tend not to be 100% "flat", so it doesn't turn out looking quite like a proper "mirror" gloss finish - more like a slightly rippled pond!
And, like the wax Andy mentioned, the T-cut can leave a bit of residue in the grain if you're unlucky.
sounds like I need one product to clean and maybe bring out some colour then another to polish up what gets revealed?
am I heading in the right direction?
I'm worried about getting something that is just too abrasive or something
Use T-cut on a cloth first - shouldn't be too hard to get a shine, especially on a nitro finish like an SG, so there's not much danger of rub-throughs unless you're really aggressive.
http://www.carplan.co.uk/index.cfm?category=58
Then use a clean cloth and silicone-free furniture polish to get rid of any residue and really bring out the shine.
That's what I do, anyway.  :)
T-cut in my mind, just feels like it would be aggressive, which is the main reason im concerned about using it.
I just found this, which might be a one stop solution as far as cleaning products goes...
http://www.dv247.com/guitars/fender-instrument-care-kit--41213
im gonna have a read through that tcut link.
I've used T-cut many times over the years.  Must admit I've had a few rub-throughs, but usually when I was doing some kind of spot repair and over-sanded the surrounding area.  :roll:
It is fairly abrasive, but much gentler than something like Brasso (never used that on a guitar, but it will, for example, take gold plate off hardware quite easily).
That Fender kit might do the trick, never tried it, but it might be a bit too gentle to shine-up a matt finish.
t-cut can be a bit too agressive if you use it too dry.  It will definately be too agressive for a faded if used with a buffing machine - but thats normally an effective way to quickly buff up a finish
but t-cut should be fine for this if you keep it moist:
I use a damp cloth, usually a bit of an old t-shirt wrapped around some wadding  so it fits in the hand nicely (similar to the way french polishers work http://www.wood-finishes-direct.com/img/prods/french-polish-big.jpg.)
i also spritz the surface with a little water first for lubrication - I buff just till it starts to drag which shows the t-cut is drying off and could start to leave bigger scratches.  then i either apply another spritz of water and more t-cut or buff it all off with a cheap yellow duster to remove residue and see how i am getting on
change the buffing rag when needed
T-cut isnt really the best buffing compound but it does work - if you want better look for something like Meguiars, farecla, mezerna.  they tend to do more 'grades', basically split into cutting compound and finishing compound
http://www.farecla.com/?screenID=125#/125
thanks for the tips.
do you use the T Cut scratch remover? or the T Cut original?
original - just because i am more used to working with it really...
but i am much preferring the more professional stuff i mentioned recently for the odd guitar i finish myself or need to polish up
Ummm... Wez/Philly
A Gibson Faded doesn't seem to have any clear coats. What you got seems to be basically the colour coat... do you really want to be using a cutting compound to buff it up?  :?
That was my reasoning, anyway, so I went the wax route instead.
By the way Dmoney - when I use Briwax, I do put it on with 0000 wire wool, but LOADS more gently than if I was doing a piece of furniture. In fact, next time I put it on the SG I'll probably use a cloth instead - I think mine's seen enough wire wool already :lol:
the way i understand it is the TCut will remove the fine surface layer blemishes and restore some colour. Then you polish that up to a shine.
your 0000 wire wool will be cutting gentle into the finish right? Its just that wax doesn't have any cutting compound in it.
The finish is a thin nitro lacquer
Quote from: AndyR on November 23, 2010, 12:18:29 PM
Ummm... Wez/Philly
Ah, didn't realise.  :oops:
I assumed it was the same as my old Pete Townshend SG - that was a satin finish but there were definitely clear coats!
Having said that, I think gwEm has polished a Faded V?  Could be wrong.
