Heavy neck-like bridge pickup?
Started by OnyxEchoes, November 25, 2010, 04:37:46 PM
OnyxEchoes
Hello. Locked my last thread here cause I thought I found the solution [c-bomb] but I've run into a problem.
I have a Fernandes Vertigo Elite (see below). Has a mahogany body and set-neck construction. I want to get a nice heavy pickup to put in this. I was torn at first between the Nailbomb and the Warpig, but then I read up on the Aftermath.
Vertigo has a sustainer placed in the neck position. I've contacted Fernandes to see if I could switch the sustainer to the bridge position while retaining the same functionality but am not hopeful. Not really sure how it works exactly but I imagine it's picking up the string vibrations at their most plentiful spot. I really hate the bridge pickup sound though on a guitar and almost always play neck or combo as I prefer a more balanced, woody, less trebly tone. I only ever use bridge if I need a certain tone on a solo.
Any suggestions on a way around this? I read another forum this:
QuoteJust a suggestion from a theoretical point of view. You could try a very high output neck position humbucker in there. Heres my reasoning. Bridge position is overwound compared to neck position to compensate for less vibration of the strings. If you put a normal neck pickup in it'll sound weak and as already mentioned in the thread a bridge pickup is gonna sound like a bridge. Put an overwound high output neck pickup in & the overwinding may compensate for the less string vibration & might sound closer to a "normal" neck pickup.
I'm not an ace at pickup theory, but isn't overwinding what gives pickups high output?
I just want a massive, dark-sounding humbucker with tight bass response and smooth, balanced highs. Don't really want the trebly tone of bridge though. One user suggested a Warpig, from what I read and heard of it this might be the option, but I was initially intrigued by the c-bomb and the Aftermath because of the ceramic magnet. Just wanted a little more input before I pull the trigger. Thanks!
Madsakre
You are the first Metal? player i've ever heard of which preferred the neck instead of bridge :P well okay. Maybe yngwie too.
Cattlepress
the neck miracle man sounds great in the bridge position
it's like an even fatter and smoother holy diver
badgermark
how about rolling the tone down on your gutar. It gets rid of treble.
OnyxEchoes
Gonna go ahead with the Miracle Man. Funny, wasn't even on my radar. Thanks for the input guys.
brian_ward
Quote from: OnyxEchoes on November 27, 2010, 04:30:37 PM
try a 300k volume pot too. rolls off some high end.
Davey
i'd suggest the warpig. it's got a REALLY meaty tone. if you use a 300k pot for volume and play around with resistors, to simulate the tone control (i am REALLY REALLY REALLY not a fan of tone pots.. they suck out all the tone from a guitar)
with this you should get a nice full, warm kind of tone and still retain all the definition of the pickup.
the C-pig is a completely different beast. it's far more trebbly. the MM is hotter than the WP, at least in its perceived volume, cos it has a lot more mids and highs. i've got all three basically in the same guitar, so i did a lot of side by side comparison.
as far as sticking an alnico in a MM, cant comment, havent heard one ever.
Lucifuge
If you do hear back from Fernandes about moving the sustainer to the bridge position, I'd be interested to hear what they say; I've been thinking about the possibility of installing the sustainer in the middle position in a 3-humbucker guitar, so I could have standard neck and bridge pickup sounds as well as the sustainer effect.
