Author Topic: Ageing a body  (Read 13177 times)
tomjackson
Ageing a body
« on: December 01, 2010, 10:33:53 AM »
I want to lightly age my strat body.  It is finished in Artic white Nitro and I'm thinking of getting an aged Fatboy plastics set so want some light wear so it doesn't look odd against the pickguard.
Manchester guitar Tech advised sticking the body in a freezer will laquer check.  Has anybody tried this?
Just after some ideas for light wear that will not make it look like I've had a go at it with some sandpaper.
The body is a 1994 AM standard body that was refinished by me and my dad with aerosols so it's not so perfect as shouldn't be messed about with.
Matt77
Re: Ageing a body
« Reply #1 on: December 01, 2010, 11:34:05 AM »
You can also buy spray to freeze it to -50 degrees instead, and then warm it up with a hairdryer
Coincidentally, I bought some on Sunday so it should arrive by the end of the week.
I can bring it round to test when I drop that pedal off if you want.
tomjackson
Re: Ageing a body
« Reply #2 on: December 01, 2010, 12:03:58 PM »
Matt, sounds good.
What are using it on?
Will my Stat be your Guinea Pig?  Lets try it on the back first!
Matt77
Re: Ageing a body
« Reply #3 on: December 01, 2010, 12:37:09 PM »
I'm going to use it on an unbuilt tele that I don't even have the parts for yet.
I'll test it on the back of my already checked and beat up gibson
Re: Ageing a body
« Reply #4 on: December 01, 2010, 04:12:35 PM »
unbuilt teles are the second best kind of teles
James C
Re: Ageing a body
« Reply #5 on: December 01, 2010, 06:45:27 PM »
Quote
the best being smashed perhaps Roo?
Formerly "ManOnTheEdge"
Sifu Ben
Re: Ageing a body
« Reply #6 on: December 02, 2010, 01:32:08 AM »
I've found that a decade of shift work and a lifetime of high impact martial arts training has aged my body considerably :(
Re: Ageing a body
« Reply #7 on: December 02, 2010, 06:55:32 AM »
Cigarettes, alcohol and prescription drugs age a body wonderfully.
Re: Ageing a body
« Reply #8 on: December 02, 2010, 07:49:57 AM »
A few non prescription drugs do too or so I have heard.
Re: Ageing a body
« Reply #9 on: December 02, 2010, 10:10:25 AM »
the spray/hairdryer will make it craze - but it isnt the easiest technique to make look natural as you tend to work on a small area at a time which can lead to an uneven effect
for more natural crazing it helps to do the whole thing at once.  but its the same hot/cold process - and obviosuly you need to watch out for the effect the heat can have on the guitar(especially necks).
but try keeping the guitar somewhere warm for a day or so to aclimatise (something like an airing cupboard - a few degress warmer than its natural environment), then freeze it for 1/2 and hour before taking it out again and putting it somewhere warm with a warm air blowing across it if possible
Re: Ageing a body
« Reply #10 on: December 02, 2010, 02:30:12 PM »
Am I right in thinking all this freezing-and-warming only works on nitro?
Re: Ageing a body
« Reply #11 on: December 02, 2010, 03:37:50 PM »
yeah, other finishes do crack with age  but not in the same way or to the same degree... they  become 'cracked' rather than 'crazed'
Re: Ageing a body
« Reply #12 on: December 02, 2010, 08:02:57 PM »
Quote
I was going with kindling, but smashed works too. At least with kindling, you actually get something good out of it (energy), rather than just splinters :)
Matt77
Re: Ageing a body
« Reply #13 on: December 02, 2010, 09:16:17 PM »
So you wouldn't like this video then Roo?
Especially 2:36
Transcend
Re: Ageing a body
« Reply #14 on: December 02, 2010, 10:21:46 PM »
Quote
yeah but smashing it would be amazingly fun for you, then you could burn it too to get the energy.
Seems like a WIN WIN situation to me
